Cam identification help
Old Jan 6, 2011 | 08:12 PM
blively's Avatar
blively
Default Cam identification help
i pulled the timing cover and cam gear off the front of the engine, and found a bunch of numbers on the nose of the cam. could someone help me out with identifying this cam i have?
here are the numbers:
R47115
10
306S
3
7
it also had another marking on it that looked like overlapping C's. so i dont know if maybe it stands for comp cams? or maybe Crane Cams? thanks in advance for the help!
Old Jan 6, 2011 | 10:52 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Take a picture of it and post it here.
Old Jan 7, 2011 | 10:05 AM
blively's Avatar
blively
Ok, I'll get a couple snapped tonight
Old Jan 7, 2011 | 01:32 PM
Ace77's Avatar
Ace77
google 306S camshaft:
one hit:
http://www.jegs.com/p/Comp-Cams/Comp...54857/10002/-1
306S Series
The 306S Solid Magnum Cam is an excellent grind for large cubic inch Pro-Street type engines. This cam has tremendous high RPM power and needs to be used with headers, intake and higher compression. This cam does not have the advance made into it and will need to be degreed in.
Old Jan 7, 2011 | 02:54 PM
blively's Avatar
blively
Sweet! Thanks for finding that Ace77!
Now that i know what cam I have, I have a question... They say higher compression needed with this cam.. How high of CR are they talking about?
Old Jan 7, 2011 | 03:47 PM
larrywalk's Avatar
larrywalk
11 or 12:1
Old Jan 7, 2011 | 05:07 PM
blively's Avatar
blively
Oh wow! I will be in the 8.5 range. What happens if I'm running in the 8.5 range with a Cam like this? What issues will that cause?
Old Jan 8, 2011 | 04:16 PM
larrywalk's Avatar
larrywalk
It will run, but it will be sluggish.
Old Jan 8, 2011 | 06:56 PM
blively's Avatar
blively
Ok. Next question... If I swap pistons and run a little over 11 CR, will I still be able to run pump gas? What's the lowest octane I would be able to use?
Old Jan 8, 2011 | 07:57 PM
scottyp99's Avatar
scottyp99
You need to do a little research about something called "dynamic compression ratio" as opposed to "static compression ratio". Google dynamic compression ratio, and you will find plenty of articles explaining what it is, and why you need to know about it. It has to do with cylinder pressure; big cams with alot of valve overlap bleed off cylinder pressure, and so need a higher static compression ratio to keep cylinder pressure up. It's all very interesting once you start to get into it, and you will be much, MUCH more enlightened about just how engines work.
Scott
Old Jan 9, 2011 | 12:31 PM
Timsride's Avatar
Timsride
I had this cam in My 70 Z28 with 10:1 comp. It had a 3500 stall, 4.11 gears and worked fine. I also had light weight pistons that let it rev faster. The one thing I think would have been nice would be a set of AFR heads and at least an 850 carb. I also had dual 3" exhaust with flowpath mufflers. I started with 2.5" with the turbo thrush mufflers, but were too restrictive. It ended up blowing exhaust out the seems all the way around the mufflers.Also the engine was built to handle 7200 RPM shifts.
Old Jan 10, 2011 | 11:50 AM
blively's Avatar
blively
Here's what I have so far for this engine:
the 306s grind cam
781 cast iron heads with 2.19 intake valves
either an edelbrock torker 2 intake, or weiend dual plane intake
And I also have an 800 holley. I'll have to get it out to see if it's a double pumper or not, but it is mechanical secondaries..
for now I am going to run a 400 auto, with a 2600 stall convertor, but am planning to swap to a 4 speed in the future.. I have stock gearing in the rear end, thinking 3.08, but haven't gotten that far into checking numbers.. But I would like to throw in a set of 3.73 gears..
Now that you guys see the stuff I have, can I make this combo work?
Id prefer to run 87 octane, but if I keep this combo, 91 octane is doable!
Also as far as pistons go, I'm looking into some Keith black silva lites, because they are a little less expensive.. What would be your recommendations? And thanks to all you guys for helping with all of this, y'all are helping me learn a lot more about engine building than just bolting parts on and going!
Old Jan 10, 2011 | 01:19 PM
Les's Avatar
Les
the 306s grind cam
For the street that's an awful lot of cam- duration @ .050 of 260 degrees on both sides is pushing it. How many cubes is your motor? If your gears are really 3.08s I just don't think you'd be happy. 3.73 would no doubt be better but I'm wondering why you're stuck on this cam. If you're planning to spend most of your time at the drag strip that's a different matter. So, how do you plan to use the car? There are some grinds that are still aggressive but would be better suited for street use. For the cost of a new cam I think it would be money well spent- again, that's if it's primarily going to be a street car.
Old Jan 10, 2011 | 02:26 PM
blively's Avatar
blively
I knew I forgot to add something in there! The engine has been bored out 60 over.. I believe 4.31 bore size. The pistons I have already are silvolites, but I don't know the dome size.. (How can I measure this to find out?)
Would you mind telling me the aggressive cams you're talking about? Cam grinds and whatnot so I can check them
out and learn the differences between them? The car will mainly be street driven, and see the drag strip a few times.. Id like to stick with solid lifters.. Id like to use the money towards a cam, since I am learning from you guys this one I have is a little much for the street..
In the beginning I wanted to try to use this cam simply because it was already in the engine and it was agressive. Now learning it's a tad too much for the street, id rather put the money towards an aggressive street cam instead of different pistons..
And for rear gears, I plan in the future to run 3.73s since they seem to be a good all around set..
Old Jan 10, 2011 | 04:15 PM
larrywalk's Avatar
larrywalk
If your compression ratio is really only 8.5:1, you might as well just use flat tappet hydraulics of 215 to 225 degrees of intake duration. If you really want solid lifters, add ~10 degrees to that. Use an exhaust duration of about 10 degrees more than whatever intake duration you pick. With this setup, a rear gear of 3.08 or 3.36 will be fine.
If you want to use a hyd, or solid, roller cam, figure and additional $800 to $1000, but IMO, I wouldn't do it unless you step up your whole combination.
BTW, a 4.31" bore 454 is 468 cubic inches.
Old Jan 10, 2011 | 04:34 PM
blively's Avatar
blively
ok thanks! 468 sounds meaner than 454 lol!
So going by your recommendations, how do you think this cam would work out?:
http://www.dougherbert.com/herbert-p...cams-9650.html
Old Jan 10, 2011 | 06:08 PM
larrywalk's Avatar
larrywalk
That should be fine with a CR of 8.5; just make sure what you have.
To Cam identification help
Old Jan 10, 2011 | 06:31 PM
scottyp99's Avatar
scottyp99
With that much cam, and 8.5/1 CR, he'll probably be able run kerosene in it!
Scott
Old Jan 10, 2011 | 07:47 PM
blively's Avatar
blively
Ok, thanks man! Going this route will save some money, and I won't have to make a whole lot of changes!
Thanks everybody for the help with this!
Old Jan 10, 2011 | 08:02 PM
Big Block Dave's Avatar
Big Block Dave
I ran this cam in a 9.86:1 454, 4000 stall converter, and 4:10's. Pleasingly choppy idle, and wicked midrange.
While it doesnt really require super high compression, I would NOT run this cam in a Corvette. Vacuum is VERY low, like 6 at idle...that cant good for power brakes or headlights on a Vette
