Help with Flowmasters
Old Apr 9, 2002 | 01:16 PM
74Coupe's Avatar
74Coupe
Default Help with Flowmasters
Getting ready to replace mufflers and pipes with Flowmaster Delta 50’s with 2 ½” pipes with H-pipe. Question to those of you who have Flowmasters, what configuration did you use, center inlet and outlet, offset inlet and outlet, center inlet offset outlet, etc., etc., etc.
What configuration allows the best fit and installation as to having them tucked up and out of the way?
Old Apr 9, 2002 | 01:26 PM
82dukman's Avatar
82dukman
Default Re: Help with Flowmasters (74Coupe)
On my 82 I used offset inlet/ outlet. Be aware, they are tough to tuck up there, they are larger than stock mufflers!!
Offset outlet made mine look most like stock and the offset inlet fit my pipe configuration. :seeya
Old Apr 9, 2002 | 01:36 PM
Gordonm's Avatar
Gordonm
Default Re: Help with Flowmasters (82dukman)
I have center inlet and off set outlet on mine. They were able to tuck mine up real nice. More hidden than the stock mufflers.
Old Apr 9, 2002 | 05:02 PM
compuvette's Avatar
compuvette
Mine are on the C4 so no help on mounting, but you will be really happy with the way those 50's sound!
Old Apr 9, 2002 | 05:49 PM
vettesite's Avatar
vettesite
I went with offset in and center out for a little wider than stock look. I like the pipes a little farther apart. Stock is offset in and offset out so the tips are more toward the license plate.
The 50's are longer mufflers and will be a very tight fit, especially with the 2.5" pipe. That size pipe requires more of a bend which makes it harder to get a larger muffler in there. :smash: That is one of the reasons I went with the 40 series. I wanted to keep a smooth bend (FLOW) with the 2.5" pipe.
Old Apr 9, 2002 | 06:12 PM
Sting Raycin's Avatar
Sting Raycin
Default Re: Help with Flowmasters (vettesite)
I used offset inlet and outlet. But mine are 40s I think they are a little smaller. They fit really great though
Jason
Old Apr 9, 2002 | 06:29 PM
dgruenke's Avatar
dgruenke
I had the 50's on my 1976. They were offset inlet and offset outlet. They were also a tight fit. However, I took them off of the car because they were so loud that they rattled the whole car and you could hear rattling when you accelerated. They sounded real good until I took the catalytic converter off. However, since you probably don't have a catalytic converter since its a '74, it will be very loud. I replaced mine with the chambered undercar exhaust from MidAmerica and I love it. Good Luck.
To Help with Flowmasters
