Headlight
Old Jan 9, 2011 | 09:31 AM
mario1979c3's Avatar
mario1979c3
Navigator
Default Headlight
How to rebuild a 79 Headlight actuator
Old Jan 9, 2011 | 09:49 AM
dannyman's Avatar
dannyman
ZIP has some technical articles;
http://www.corvettemagazine.com/2002...s/lights-1.asp
click continue to move through the steps.
Old Jan 9, 2011 | 10:11 AM
Peterbuilt's Avatar
Peterbuilt
In the last picture shouldn't the big end of the seal go on the shaft first?
Old Jan 9, 2011 | 11:22 AM
Alan 71's Avatar
Alan 71
Hi pete,
They seem to be indicating that the seal rolls over itself as the rod moves in and out. The rod doesn't slide through the seal, it rolls it.
That's what I think.
Regards,
Alan
Old Jan 10, 2011 | 10:11 AM
78IndyPace's Avatar
78IndyPace
Appears to be a conflict between two articles on corvettemagazine.com on how to install new actuator seals. Here are the photos from those articles showing the seal being installed:
The left photo is from the article linked to above in dannyman's post, the right photo is from this article:
http://www.corvettemagazine.com/body...both-open.html
Will someone who's done this repair please chime in an tell us which is correct?
Thanks!
Jerry
Old Jan 10, 2011 | 10:15 AM
Peterbuilt's Avatar
Peterbuilt
The right side picture is correct.
Old Jan 10, 2011 | 10:18 AM
Mike Ward's Avatar
Mike Ward
Thanks!
Jerry
The one on the right is correct. Installing the seal as per the left photo would be impossible.
Old Jan 10, 2011 | 10:47 AM
78IndyPace's Avatar
78IndyPace
Hi Mike & Pete,
THANKS!
Old Jan 10, 2011 | 08:13 PM
mario1979c3
Navigator
thanks for the help. and quick replys. now to find the time to do it
Old Jan 22, 2011 | 12:29 PM
twinpack's Avatar
twinpack
Thanks!
Jerry
I know i'm late to this, but I am doing this today. The left photo is the way my orignal ones are.
Old Jan 23, 2011 | 09:50 AM
78IndyPace's Avatar
78IndyPace
Don't know how to solve your dilemma. Zip, Willcox, & Corvette Central all show a single actuator set for all C3 years, including 1968, so I can just guess that the seal may have been redesigned at some point but the unit's form, fit & function remained the same for all years.
I would go ahead and install your new seals as shown in the RIGHT hand photo above, then test your actuators with your vacuum pump BEFORE reinstalling in your car. If the the rods move correctly and they hold vacuum in both the extended and retracted positions, you're good to go. Just my 2 cents.
Good luck!
Jerry
Old Jan 23, 2011 | 10:01 AM
Mike Ward's Avatar
Mike Ward
I'd pay money to see a picture of that.
Old Jan 24, 2011 | 07:58 AM
twinpack's Avatar
twinpack
Here's a few pictures. I already started one headlight rebuild but have not touched the other.
[IMG][/IMG]
Working on this one. I left the seal in place to prevent paint from getting in.
This is what I started with.
[IMG][/IMG]
Hopfully you can make out the seal in place.
[IMG][/IMG]
Old Jan 24, 2011 | 09:47 AM
Mike Ward's Avatar
Mike Ward
I can sort of see it. Bubba has visited your car, please take the opportunity to install it correctly. Neither sealing surface will be located correctly with it in backwards.
Old Jan 25, 2011 | 01:00 AM
Oldguard 7's Avatar
Oldguard 7
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Not to be knit picky but it seems the pics got pretty blurry.
To Headlight
