Who knows??
Old Jan 9, 2011 | 03:38 PM
AvRog's Avatar
AvRog
Default Who knows??
Is the flexplate on a bb 1970ish 454 specific to that particular engine build or will it work on any 454 of the same generation and type?
Old Jan 9, 2011 | 07:34 PM
gbvette62's Avatar
gbvette62
I don't have any of my GM parts books at the house (they're all in my shop), but I think that any 454 flexplate up to 1990 will work. If I remember correctly, all 454's with the two-piece rear main seal, use the same flexplate, where as the 91 and later 454's with the one piece seal, use a different flexplate.
Hopefully, someone else will chime in with a more definative answer.
Old Jan 10, 2011 | 06:56 AM
AvRog's Avatar
AvRog
The 454 flexplate has a balance weight welded to it, does that mean if it were to replaced, you would have to balance the motor like we would a tire installation??
Old Jan 10, 2011 | 07:16 AM
L88Plus's Avatar
L88Plus
All 454 flex plate should be balanced the same, there should be no reason to have to mess with the weight that's welded onto it. As long as the shop knows it will be an externally balanced big block, they'll balance the rest of the rotating assembly accordingly.
Old Jan 10, 2011 | 11:04 AM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
If it's a stock 454 flexplate and was not balanced specifically for your engine, then a stock replacement will be fine.
On the other hand, if during a rebuild of your engine, it was balanced by a shop by drilling another hole or adding weight to your flexplate, you would need to do the same balance modification to the new flexplate. Typically, external balance engines like the 400 and 454, are balanced with their harmonic damper and flywheel (or flexplate) in position on the crankshaft. If the shop balances the crank by adjusting the crank and leaving the harmonic damper and flywheel/flexplate alone, then part by part replacement is unaffected.
Old Jan 10, 2011 | 03:03 PM
AvRog's Avatar
AvRog
If I buy a 454 flexplate will it have a weight on it?
Old Jan 10, 2011 | 04:04 PM
larrywalk's Avatar
larrywalk
Yes; a 454 factory (or replacement) flexplate will have the correct factory imbalance for a stock 454.
Old Jan 10, 2011 | 04:20 PM
AvRog's Avatar
AvRog
Thanks, I hate to appear slower than I am, but a weight adder before knowing the specific engine was blowing my mind. So there is a constant known balance weight for the 454 in general, thats just weird but I will roll with it.
Later, Rog.
To Who knows??
