71 a/c post
Old Jan 9, 2011 | 06:35 PM
r66stingray's Avatar
r66stingray
Default 71 a/c post
Any comments on switching a stock a/c compressor over to the new freon. Overheating problems? Any issues to be carefull of?
Car is a stock 350 plain jane automatic
Any help would be appreiated
Steve
Old Jan 9, 2011 | 07:06 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
My comment: you wont be happy. r134 doesn't do near the job R12 does
Old Jan 9, 2011 | 09:15 PM
roger3's Avatar
roger3
The R-12ac in my 71 blows very cold.
My 76 with R134 does not blow nearly as cold and cycles wayyyy tooo much.
I recommend staying with R-12 if you can.
Good luck
Roger
Old Jan 10, 2011 | 12:06 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
R134a well not be as cool as R12 for one reason, it simply needs another kind of condenser (parallel flow), I have a VERY hot climate in summer and use R134a and it freezes the h*** out of me! .. use a prallel flow condenser and R134a will be just as good.
Old Jan 14, 2011 | 09:25 PM
r66stingray
Gentlemen
Thank you for the information!
Steve
Old Jan 20, 2011 | 07:48 AM
bobbarry's Avatar
bobbarry
I've got a '71 with the stock A/C, but which doesn't work.
Given the cost of a recharge with R12, and the (likely) potential cost of replacing/repairing components to get it back to fully-operational condition should a simple recharge leak out and need to be recharged again, my plan is to bite the bullet and install an entire updated R-134a-based system.
If mine still worked, however, I would NOT think about changing it over.
To 71 a/c post
