Let me start by stating I'm NO mechanic.
and i know diagnosing issues over the internet is a all but impossible but i'm hoping for some advice.
I have a local mechanic. but right now i cant afford the $90 an hour rate
1978 l-48 silver anniversary with a intermittent grinding\rubbing noise from driver's side rear. it almost feels like something catching? only occurs after 25-30 minutes of driving. My first thought was the brakes were not releasing correctly (ALL parking brake hardware removed by previous owner)
checked caliper and it appeared fine. rotor had seen better days and was very slightly warped. so i replaced both rear rotors and pads.
drove great till about the 35 minute mark then the sound reappeared.
so now im stuck. i dont know what else to check. i thought rear bearings but the sound isnt a squeal and i didn't think they would take 30 miles of driving to start showing signs of failure.
could it be the differential maybe. but it only comes from drivers side.
any help\advice or even just encouragement would help.
sorry so long winded
Drain rear diff add the additive and correct LSD oil, make several fig 8 turns
J Smit
Sounds like the classic posi clutch chatter problem.
Mainly when your pulling away from a stop sign ?
Eyeball your u-joints for signs of rust coming from the 4 cups,no rust,don't fret just change your fluid w additive and drive some and see if it goes away.
Roll down your windows and drive slowly in an alley or someplace with walls on your sides. Listen for the noise. Usually a u joint will have a double squeek. Squeek squeek for lack of a better description. A wheel bearing will normally have a rythmic squeek. The U-joint will move two directions with every turn of the wheel where the bad wheel bearing will sound like the noise is coming from one spot of the wheel.
Unless the wheel bearing is in very bad shape from being bad for a longer lenth of time. Then it will be a constant squeek.
Sounds very much likewhat I had on my 77, a grabbing sort of feel on the driverside wheel. Only after driving a while, and only at a stop then takeoff. Felt like the tire was loose, or brake caliper was grabbing. Long story short, pulled the rear end, replaced a worn yoke on driverside, and new rear end oil and posi addative, Have driven a year on it now and have never felt or heard it again.
If I were to change the fluid in the differential what fluids should i use. what viscosity and its a limited slip does that require a special additive?
can these be purchased from a parts store or should i order them online
When you replaced the rear rotors did you have to drill out the rivets? Check to make sure a rivet or piece of rivet left in the hub couldn't be the culprit. With the parking brake hardware removed therre would be less for the rivet to cach on and grind against the inside of the hub but you never know.
My posi clutches went out last year. I was quoted by a corvette shop ($100/hr) around $1100 for parts & labor, plus $2oo for new stob axles if needed. I pulled it myself and had a GM mechanic friend replace the clutches, he charged $200.
If yor car starts acting up after 20 minutes and chatters when you turn, that's probably you problem.
There's no drain plug on the rear end, you have to suck out the fluid.
If you take the car for a drive, it'll warm up the diff fluid and make it easier to suck out, but don't let it get too hot, or you'll burn your lips on the diff cover.......
I know you said the park brakes were removed but IF the cables are still in the car they can easily rub on the inside of the tires, makes a terrible noise, mine actually rubbed on the wheel weights and make a loud tap tap sound as the wheel turned. Look underneath for the wire wound cable from the hub to the frame clamp and make sure they have at least half inch clearence from the tire.
well i appreciate all the advice.
nothing rubbing and wheels seem to have very little play
I guess my next plan of action will be to change the fluids in the differential. so here's my next question what's the right fluid and additive to use.
exp- would it be better to use stock from gm or some kinda performance fluids such as lucas or royal purple.
and can these be bought at a parts store? locally i have autozone,advance,or orielly's
what are they called?
Most agree to use the GM fluid and GM additive and you can get both at your Chevy dealer.
I agree with trying this first as it seems to fix most issues that are similar to that which you described. Be sure to use the GM additive and not a generic type. 4 oz bottle is usually enough. If this doesn't work go the next step.
