stereo question
Old Apr 9, 2002 | 08:04 PM
chevyman's Avatar
chevyman
Default stereo question
Where can I get a box or a mounting board . I want to install 2 6x9's in the rear . Who has one of these.
Old Apr 9, 2002 | 09:08 PM
Fevre's Avatar
Fevre
Default Re: stereo question (chevyman)
I had a 10 inch sub in a small bandpass enclosure and two 6X9 in small boxes and it rocked. Good things is I could take the sub out if I thought there was any chance I might need the room and still rock pretty good plus I had 6 foot of speaker wire connected to the 6X9 so I could pull em out and rock outside the car. Only problem is I can't get ride of the radio interference so I put the sub and amp in the Highrider.
Old Apr 9, 2002 | 09:12 PM
vettfixr's Avatar
vettfixr
I don't know if it will help but if you go to my website in my sig you can see my setup. I installed two amps, a graphic EQ, 12 disc CD changer and a subwoofer under the back deck. I run 4 4x6 Blaupunct speakers in the front and it sounds pretty good.
Old Apr 9, 2002 | 09:13 PM
docmow's Avatar
docmow
2021 C5 of the Year Finalist - Unmodified
had mine built at a stero shop and lhey press fit behind wheel humps in the open space to rear bulk head
worked gerat sounded good untill took out for ncrs judging last year
Old Apr 9, 2002 | 09:22 PM
dman535's Avatar
dman535
Default Re: stereo question (docmow)
You can buy these style truck speakers pretty cheap. I can still fit the t-tops in there and they will come out by just disconnecting the wires.
Old Apr 9, 2002 | 09:31 PM
Armstrong's Avatar
Armstrong
There is a multitude of choices out there. You can take the easy way out and just buy some boxes or build your own. I like the build your own approach.
Old Apr 9, 2002 | 09:32 PM
chevyman's Avatar
chevyman
The problem with mine is that my 6x9 are in two seperate boxes. WHen i drive around it slides around. Plus it looks cheap.
Old Apr 9, 2002 | 10:09 PM
Fevre's Avatar
Fevre
Chevyman
Yea, think your right about looking cheap, but lucky I cant see mine. Think I would have to go the built in custom route, looks nice.
Old Apr 10, 2002 | 01:45 AM
PyjamaSam's Avatar
PyjamaSam
From: At the end of 2 big long black marks on #2 Sideroad and Walkers Line.
Default Re: stereo question (Armstrong)
Armstrong:
I love your set up. I think is looks friggen amazing. Nice job
To stereo question
