Fuel Line Problem
Old Apr 9, 2002 | 10:03 PM
bence13_33's Avatar
bence13_33
Default Fuel Line Problem
I have everything disconnected from the engine with the exception of the two rubber fuel lines that run to the fuel pump(and of course the two motor mount bolts). There are two metal fuel lines that run parallel to each other down the frame of my car from the gas tank up to the fuel pump where they are spliced into the fuel pump with rubber fuel lines. The problem is this, whenever I disconnect the larger rubber fuel line from the metal fuel line ; fuel comes spilling out. I've tried everything I can think of to keep the fuel from coming out but nothing seems to work. Is it going to be easier to empty all the gas out and then pour it back in when I am finished or is there an easier way that I am missing?
Ok guys let's put on our thinking helmets :)
Old Apr 9, 2002 | 10:09 PM
jaggeedfire's Avatar
jaggeedfire
Default Re: Fuel Line Problem (bence13_33)
Mine does the same when I replaced the lines. I just thought though...what about putting
a vacume on the return line??? Id like to try this and see if it works. I have a vac
pump so maybe???
Nicholas
Old Apr 9, 2002 | 10:10 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Why not disconnect the rubber hoses from the pump and clamp them off there? That's what I did when I changed my pump.
I read someone else clamped(a shop towel & vice grips) it off back at the tank and drained the line.
[Modified by 1970 Stingray, 9:11 PM 4/9/2002]
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Bence,
I had this problem too when I pulled my motor also. What I did to stop the fuel from going everywhere was find a bolt the sized of the rubber fuel line and put it in the end of a short piece of the rubber fuel line. This was slipped over the big fuel line and no more leaks.
TA-DA.
I had to ask what to do here too. Someone pointed this trick out to me also.
Hope this helps.
MikeC's Avatar
MikeC
I always cut the flow of fuel with vice grips on the hose.
This just means your fuel level is higher than the outlet of the fuel line, the fuel will drain until the levels have gone below the outlet of the fuel line.
I say plug the fuel line as above and when you replace the line just do it quickly.
Old Apr 9, 2002 | 10:17 PM
bence13_33's Avatar
bence13_33
Default Re: Fuel Line Problem (MikeC)
Jeez, seems so obvious...I guess I'm just a little slow :). I'll try the vice grip trick tomorrow when I yank the engine out. I can't wait to start cleaning up that engine compartment, it's a real mess!
As always guys thanks for your help! :cheers:
Old Apr 9, 2002 | 10:24 PM
MikeC's Avatar
MikeC
You're gonna make a good wife one day! :jester
[Modified by MikeC, 8:24 PM 4/9/2002]
Old Apr 9, 2002 | 10:27 PM
Eddie 70's Avatar
Eddie 70
Bence, I gotta get started cleaning my engine compartment tomorrow. Wanna help with mine?
Good luck.
Old Apr 9, 2002 | 10:29 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Default Re: Fuel Line Problem (Eddie 96)
Hey, anybody see that Steam Cleaner on QVC & late night TV?? supposed to work wonders in engine compartments.
Get this----my wife has been asking ME to order one???? :eek: :confused:
Bence I just order TRW 2399F60 pistons---are they the same as yours? 0.060+?
[Modified by 1970 Stingray, 9:32 PM 4/9/2002]
Old Apr 9, 2002 | 10:30 PM
andyg's Avatar
andyg
My solution. 2 long rubber lines and had my wife hold them above the height of the tank. She is always helpful. Glad she is there. :yesnod: HEHEHE....
---Andy
Old Apr 9, 2002 | 10:31 PM
INTIMIDATOR ZO6's Avatar
INTIMIDATOR ZO6
bence13_13, relief some of the pressure by taken the gas cap off...if it still leaks put a plug on it! :D :yesnod:
Old Apr 9, 2002 | 10:40 PM
bence13_33's Avatar
bence13_33
Mike:
It's funny you should say that lol. Every time my buddy sees how clean my car is he responds with "you're just like a d@mn woman" :D.
Eddie:
I would, but I think I'm gonna have my hands full with mine :).
1970 Stingray:
Yes the 2399F60 pistons are the ones that I have in my engine. They have a slight dome and with my closed chambered heads will put me around 10.5-11:1 compression ratio.
Intimidator454:
Yep, tried the gas cap trick but the gas still spilled all over the place.
Old Apr 10, 2002 | 03:01 AM
stroked 76's Avatar
stroked 76
hey bence if you need to know any little tricks for doing your engine compartment get back at me,i just did mine for 383 transplant and it looks kick butt way better than i thought it would look.lots of complemants from people.it did it pretty cheap too.also put a 3/8 bolt in your feed line from steel fuel line and tighten clamp up again,the other line is your return which you won t use again with a aftermarket carb and fuel pump
To Fuel Line Problem
