Header Installation Tips?
Old Jan 13, 2011 | 03:10 PM
trainor's Avatar
trainor
Default Header Installation Tips?
Does anybody have any good tips on installing header to ensure that there are no leaks. Is there a tightening sequence? Thanks
Old Jan 13, 2011 | 03:38 PM
1yy07's Avatar
1yy07
Default header
www.stage8.com get the 1" ones and dont forget thin flat washers
Old Jan 13, 2011 | 06:13 PM
baxsom's Avatar
baxsom
percys headers gaskets, i have also read that you can cut the flange between each header.
Old Jan 13, 2011 | 06:40 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Did that on my Nova and it worked great.
Old Jan 14, 2011 | 08:16 AM
gkull's Avatar
gkull
do you have aluminum heads?
Old Jan 14, 2011 | 01:33 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I don't understand the problem with header leaks. I either never have them or can't hear them over the noise of the motor.
A flat true header flange a new Felpro gasket and heads that are clean and I just use ordinary $10 header bolts.
Old Jan 14, 2011 | 05:41 PM
trainor's Avatar
trainor
Yes I do have aluminum heads.
Old Jan 14, 2011 | 09:11 PM
Duke94's Avatar
Duke94
Percy's multi layer gaskets and Stage 8 bolts Used both on my 78' and haven't had a leak in 5 years of use.
Gary
Old Jan 14, 2011 | 09:28 PM
snoopykissedlucy's Avatar
snoopykissedlucy
I use dead-soft aluminum gaskets on the collectors to prevent blowouts.
Old Jan 16, 2011 | 04:28 PM
MotorHead's Avatar
MotorHead
Yeah I use those aluminum collector gaskets they work great, I have had leaks there before I started using them, and they can be used over and over
To Header Installation Tips?
