Chirping side pipe
Old Jan 13, 2011 | 06:44 PM
STODD's Avatar
STODD
Default Chirping side pipe
When I installed my new hooker super flows in my side pipes the passenger side has a chirping sound. I did not have this problem with the reverse flows. I removed it, cleaned some slag out of it, made sure they were round and fit nice and I still have it.
Any one ever have this problem? Thanks, Steve
Old Jan 13, 2011 | 08:41 PM
ZoraC3's Avatar
ZoraC3
What kind of "chirping sound"? Is it an rhythmic exhaust, high pitched sound? Could it be an exhaust leak popping sound?
Old Jan 14, 2011 | 12:36 AM
sly vette's Avatar
sly vette
I'm gonna take a wild guess and say the insert is moving slightly in the sidepipe.
Old Jan 14, 2011 | 07:25 AM
L88Plus's Avatar
L88Plus
Racers love this sound but nobody actually seems to know what causes it. It seems to have something to do with cam profiles, particularly the exhaust valve closing, but it's tough to replicate.
Old Jan 14, 2011 | 07:45 AM
U17's Avatar
U17
Does it stop after they are warmed up ?? Mine does...
Old Jan 14, 2011 | 09:27 AM
STODD's Avatar
STODD
My buddy said the same thing about drag cars but did not say what he thought caused it. It is a very rough idle, flat tappet solid cam, copied the build from one of Hot Rods 383 builds but is a 406. I can't remember cam profile and am out of town now, but is a comp cams grind.
It is not an exaust leak, putting my hand over the end of the pipe stops it. I will probably swap inserts from side to side when I get home and see if it follows. Thinking I will go back to my glass pack(not reverse flows like I earlier mentioned) except when racing as these things are really loud and not sure I like the tone either. I will say performance wise though it is like whole different car with the super flows.
Thanks for all the in put
Old May 16, 2022 | 12:23 PM
RobiusPrime's Avatar
RobiusPrime
Cruising
I know this is a very old thread... however, did you ever figure out the issue? I have nearly the identical issue where it chirps until I put my hand in the way of the pipe. Amy insights would be appreciated.
Old May 16, 2022 | 06:04 PM
TX427C3's Avatar
TX427C3
Active Streak: 90 Days
St. Jude Donor '06-'09,'22,'25
Not a good idea to open really old threads, recommended to start your own new
EDIT: Cool, I see you did
Old May 18, 2022 | 11:25 PM
RobiusPrime
Cruising
Yet, no replies... seems I'm unique on this endeavor. Not good.
To Chirping side pipe
