Fuel filter???
Old Jan 17, 2011 | 04:41 PM
midyearvette's Avatar
midyearvette
Originally Posted by alswagg
Even if I was going to use the mechanical pump, there is absolutly no problem running a filter between the pump and tank. This has been done for years. I have installed probably over 200 filter systems like this. This is an OEM position for every Mercruiser engine made for the last 10 years. It is crazy to not have a filter on the fuel system. The recircuting system found on many of these cars are perfectly capable of flowing proper fuel flow with an inline suction side filter. I am tired of getting snide comments, when I was only asking if the C3 had an inline filter somewhere prior to the fuel pump! Al
it seems these issues always come up and the inevitable comparison is a boat to a car!!....marine mills run mucho cooler than their auto counter parts which helps tremendously with vapor lock and usually there is a lot less distance from the pump to the tank which does make a difference for the suction side of the pump albeit very slight....bottom line is under heavy wot usage the mill can out run the fuel pump if there is slight restriction on the suction side as opposed to the pressure side.....marine mills incorporate water separators because of their enviornment and that most boats sit at dock as much or more than they are operated in very humid conditions
i did not mean to offend the op in any way, my apologies if i did, juz try'n to help out......
Old Jan 17, 2011 | 04:49 PM
alswagg's Avatar
alswagg
No apologys needed, Marine engines run at much higher rpms than most automotive for extended times. Current 5.7's run at 5,500, Current 6.0's run at 6,200. In the 80's and early 90's 5.7's ran at 4,600. This is a consistant run for hrs at WOT. Many fuel lines in small boats are very short, but in cruisers the fuel system may be 10 to 15 ft long.
I just did not want to install a filter if a OEM filter was present. Thanks Al
Old Jan 17, 2011 | 05:13 PM
Thinpockets's Avatar
Thinpockets
I have a Sierra marine fuel filter/water separator that I will install on my 72. It makes perfect sense on a car with a 40 year old tank and lines to filter the crude and water out. I don't know how water gets in there but it does.
It's a spin on type filter, like an oil filter, so I assume it would be installed on the vacuum side?
Old Jan 17, 2011 | 05:49 PM
alswagg's Avatar
alswagg
Exactly Al
