Intake Removal Question
Old Jan 16, 2011 | 04:20 PM
DO2G's Avatar
DO2G
Default Intake Removal Question
Is there any reason to remove the carb and intake separately? It seems like it would be easier and quicker to remove the intake with the carb still attached.
Old Jan 16, 2011 | 04:24 PM
mds3013's Avatar
mds3013
No reason I can think of. mike..
Old Jan 16, 2011 | 04:25 PM
fugawi's Avatar
fugawi
you don't have to,but the carb may get in the way of intakebolts. it's only four bolts and a two dollar gasket to remove..
Old Jan 16, 2011 | 08:54 PM
tnovot's Avatar
tnovot
Another reason to separate (could be done after removal as a unit) would be when you go to reinstall. An intake by itself would be lighter and easier to position onto the gaskets.
Terry
Old Jan 17, 2011 | 04:40 AM
vetteguy22's Avatar
vetteguy22
I just R & R my intake with the carb on it last weekend. The carb does not add much weight but it is a little harder to get the manifold torqued properly with the carb on unless you have the proper tools.
Old Jan 17, 2011 | 05:12 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Another tip is to remove your distributor cap and rotate the rotor until it's lined up with the firewall. Put a piece of tape on firewall with a line across from the rotor. This makes it alot easier to reinstall the distributor and have it lined up properly than guessing if its pointing to cylinder #1 which is a common method
Old Jan 17, 2011 | 07:58 AM
DO2G's Avatar
DO2G
All good stuff...thanks.
To Intake Removal Question
