Interior Paint
Old Jan 17, 2011 | 08:12 AM
Cobfree's Avatar
Cobfree
Default Interior Paint
I am trying to restore the shift plate in my 68. I have cleaned the plate down to the bare metal and b-4 I paint it with the Hi-Tech lacquer I need to know if there is a special primer that should be used. I painted it once on top of the existing paint and it looked bad.
It is very time consuming masking and did not want to do it a third time.
Old Jan 17, 2011 | 09:38 AM
oldsarge's Avatar
oldsarge
I used Dupli-color trim paint direct to the metal, had no problems.
Old Jan 17, 2011 | 09:48 AM
1974ta's Avatar
1974ta
Plate painting.
Did it on my 70 and to do it right is very time consuming. I used Krylon Semi Flat for paint. I tried tape and did not like it. I ended up using very sharp razor blades to get the paint off and lacquer thinner to do final detail
Mine looks factory new and was worth all the work. One key I found is that the razor works best once paint is tack free but not dry. It will chip even with a new blade if you let it dry too much. Edges go quickly. Lettering took a while.
Bill
Old Jan 17, 2011 | 06:02 PM
Alan 71's Avatar
Alan 71
Hi,
I, too, have had good results with spraying the entire plate and using a new x-acto blade to slice the paint off the chrome surface as soon as the paint flashes.
Give it a try?
Regards,
Alan
Old Jan 17, 2011 | 06:12 PM
thegazman's Avatar
thegazman
Default thegazman
If you prime it, use a primer of the same brand and type as the finish paint.
Old Jan 17, 2011 | 08:33 PM
shrekviper's Avatar
shrekviper
Bill/Alan,
Did you use one or two coats? If two, did you just wait a few minutes then hit it with another light coat? I'm about to do my gauge cluster and don't want to go through the pain of stripping again...
Scott
Old Jan 18, 2011 | 04:56 AM
CraigH's Avatar
CraigH
I stripped mine.
Then painted it with satin black enamel. I know enamel is not original but after trying a few paints it produced the most robust finish and the best satin black i could find. Used multiple coats allowing the paint to flash between.
Once it had dried I used a razor blade to remove it from the areas that should be chrome.
More detail here on my update thread.
http://www.australiancorvettes.com/p...=asc&start=312
(and on previous pages it covers sub components of the console trim plate, heater controls etc).
Craig
Old Jan 19, 2011 | 01:48 PM
RizVet's Avatar
RizVet
Eastwood Satin Black wheel paint is an exact match for black metal trim pieces.....
Old Jan 19, 2011 | 01:50 PM
Cobfree's Avatar
Cobfree
Well, I will put a primer on tonight and paint it tomorrow. Let you know. Thanks for all of advise.
Old Jan 19, 2011 | 03:48 PM
Alan 71's Avatar
Alan 71
Hi Craig,
Very nice looking work, and pictures,too.
Regards,
Alan
Old Jan 19, 2011 | 04:25 PM
CraigH's Avatar
CraigH
Originally Posted by Alan 71
Hi Craig,
Regards,
Alan
Thanks Alan
Have been trying to document everything I have done on the vette.
Craig
Old Jan 20, 2011 | 02:30 AM
upcominZ's Avatar
upcominZ
Originally Posted by CraigH
I stripped mine.
Craig
What did you use to trip the original paint?
Old Jan 20, 2011 | 02:33 AM
CraigH's Avatar
CraigH
I used a product called citrus-strip.
Less caustic than some of the other strippers around but does a good job.
Then cleaned it off with thinners.
Craig
Old Jan 20, 2011 | 02:39 AM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
May I suggest SEM Trim Black #39143
Needs no primer. Exact match to the factory finish and resists chipping.
Old Jan 20, 2011 | 08:52 AM
Cobfree's Avatar
Cobfree
Where did you purchase SEM Trim Black? My 68 console has a smooth finish vs. your textured. I will follow your path as I am about to strip it for the third time.
Old Jan 20, 2011 | 01:13 PM
MiguelsC2's Avatar
MiguelsC2
Heres one link.
http://www.sjdiscounttools.com/sem39143.html
Do a google search and you will find many more.
Old Jan 20, 2011 | 01:45 PM
Cobfree's Avatar
Cobfree
Will do thanks
Old Jan 20, 2011 | 03:32 PM
Alan 71's Avatar
Alan 71
Hi cf,
Often your local auto body supplier will have SEM paints since it's pretty well known and popular.
Regards,
Alan
Old Jan 31, 2011 | 07:38 AM
Cobfree's Avatar
Cobfree
Many thanks for all that commented on painting the shift plate on my 68 four speed. Finished it this weekend and it looks better than new.
To Interior Paint
