Upper control arm bolts keep untightening
Old Jan 18, 2011 | 12:37 AM
big454blockchevy's Avatar
big454blockchevy
Default Upper control arm bolts keep untightening
I keep having to tighten the upper control arm bolts . I tried permanent lock tite and they still come loose. Anybody have a clue as to why?
Old Jan 18, 2011 | 09:40 AM
Alan 71's Avatar
Alan 71
Hi 454,
Are you asking about the bolts to the frame, or the bolts through the bushings into the end of the control arm shaft.
Regards,
Alan
Old Jan 18, 2011 | 11:02 AM
sly vette's Avatar
sly vette
If its the bolts at the bushings and you have "poly" that may have something to do with it.
As I understand it...Locktite will usually solve the problem though.
Good Luck!
Old Jan 18, 2011 | 11:30 AM
pepegriffo's Avatar
pepegriffo
If the frame bolts are turning, the knurled bolts have loosened. You could try new knurled bolts. I just finished bushing install. One frame bolt was loose so I tack welded the bolts in place. You might be able to get a wrench behind the frame to tighten the bolts rather than take the control arm off for a fix.
Tough job either way.
Pepe
Old Jan 18, 2011 | 01:23 PM
big454blockchevy
Originally Posted by Alan 71
Hi 454,
Regards,
Alan
The bolts to the control arm shaft. Let me take a pic will post it in a few minutes.
Old Jan 18, 2011 | 01:45 PM
big454blockchevy
OK, was going to post pics but batteries in camera are low. Went back out to tighten them , don't want to brake though. Yes , I am that strong.
Old Jan 18, 2011 | 04:03 PM
cvar33's Avatar
cvar33
just add another nut and use it as a jam nut. Or.... use a nylock nut or lock nut in place of the "normal" nut you are using now.
Old Jan 18, 2011 | 04:57 PM
Belgian1979vette's Avatar
Belgian1979vette
Probably because you have poly's in there. The problem is these turn on the shaft. The bolt is in the shaft and thus fixed. The bushing therefor turns on the large washer and tries to turn the bolt loose also. That's why. The design of the shafts was for use with rubber which uses internal friction to resist the motion. The internal sleeve doesn't turn in a rubber bushing, keeping the bolts tight.
To be honest, there is only one way to keep those bolts tight and that is to uses a threaded shaft into the end of the shaft and welding that, then use a castle nut.
Old Jan 18, 2011 | 05:31 PM
stock76's Avatar
stock76
Take a look at the other thread in the C3 General Forum titled ""Poly or Rubber". Your answer might be there too.
To Upper control arm bolts keep untightening
