even if you only drive 500 miles a year i'd still go with the afr's, cnc-motor sports has them for 1465.00 and when compare flow numbers the afrs out flow rhs and brodix. but rhs & brodix out flow the stock 882 smog heads, even with the flat tappet cam you will still want to run 2000 to 2400 rpm stall.
Is that price for both heads? I have a 4 speed with 3.70 gears. Thanx.
that is for both heads, it may be special order, but it shouldn't take that long to get them. i beleave they sell the flat tappet camshaft that you want to. there prices are real competitive with summit or jegs. if i remeber right summit and jegs special order most heads, or atleast that seemed the case when i visited there store in sparks nv.
