New 72 owner needs some info
Old Jan 18, 2011 | 09:05 PM
jetmech's Avatar
jetmech
Default New 72 owner needs some info
I need the emissions diagrams for a 72 200 horse auto car with a/c. I bought a 72 vert last weekend and I am now in the fix things right mode. Pretty nice car but I should have looked at the car harder than I did when I made the offer.
Old Jan 18, 2011 | 09:47 PM
VCuomo's Avatar
VCuomo
If you don't already have it, get the NCRS AIM and, while you're at it, get the electrical diagrams too for your '72. It will be money well spent.
And the '72 doesn't really have much in the way of emissions control (TCS solenoid, AIR pump, PCV, coupla' other minor bits and pieces)...
Old Jan 18, 2011 | 10:04 PM
z10kl's Avatar
z10kl
Show us some pics
Old Jan 19, 2011 | 04:38 PM
Alan 71's Avatar
Alan 71
Hi jm,
72 NICE!
The 72 base engine cars didn't have any of the AIR equipment that some of the other engines had unless it was a car delivered to California.
All 72 cars have an ECS (Evaporative Control System) which controls gas tank vapors, a PVC (Positive Crankcase Ventilation) which controls crankcase vapors, TCS (Transmission Controlled Spark) system, and an Anti-diesel Solenoid.
I hope this is enough info to get you started.
Regards,
Alan
PS: The 72 AIM (Assembly Instruction Manual) from G.M. (not the NCRS), and the G.M. 72 CHASSIS SERVICE MANUAL will both be a BIG help to you as you get to know your car. Both these are available from many of the larger venders and are well worth their cost.
Old Jan 21, 2011 | 08:41 AM
jetmech's Avatar
jetmech
thanks gents. I will purchase the assembly manual. It appears that the tcs has been disabled. What I am looking for is the lines from the evaporator canister to the pcv and the carb. The car I have has been changed up and I would like to get it back to original. Thanks again.
Old Jan 21, 2011 | 09:55 AM
Alan 71's Avatar
Alan 71
Hi jm,
Here are some pictures of the connections at the canister and the hose connections at my 71 q-jet which should be the same as your 72 q-jet.
I hope they help.
Regards,
Alan
TOP (1 from tank, 2 to carb)(1 directly to carb, and 1 to PVC and then to carb.)
BOTTOM (drain hose)
Old Jan 21, 2011 | 11:18 AM
Mashman's Avatar
Mashman
Alans pictures show perfectly how to hook up the lines to the vapor canister, as they are the same 71->72.
But don't get confused by the solenoid on the carb, that is an excellent example of the one year only CEC (Combined Emission Control) solenoid. It combines the TCS solenoid, that controls vacuum advance, with the idle stop solenoid on the carb. So your 72 will have a TCS solenoid on the rear passenger side of the carb. And a idle stop solenoid with a single electrical connection on the drivers side of the carb.
Old Jan 21, 2011 | 03:52 PM
jetmech's Avatar
jetmech
Alan that is a beautiful engine compartment. And Mashman thanks for pointing out the solenoid. Mine only has the one elcetrical wire running to it.
Old Jan 21, 2011 | 04:31 PM
Cajun-in-tx's Avatar
Cajun-in-tx
PM me your email I have a few docs on the 72 I can send you.
To New 72 owner needs some info
