82 doesn't start
Old Jan 18, 2011 | 09:42 PM
jimlynn1's Avatar
jimlynn1
Cruising
Default 82 doesn't start
I have an 82 crossfire automatic that's been sitting for 3 years . Problem is nothing happens when ignition is turned on , no instrument panel or other power up functions come on, battery is good , car will start when
starter is jumped. Turning key all I get is clicking from e-brake housing area from a small relay. ??
Old Jan 19, 2011 | 08:52 AM
jdp6000's Avatar
jdp6000
There only 2 things in the E-brake area. Fuel pump relay and anti theft relay.
Check all the fuses first. There is an anti theft fuse, check that one but also check the others.
If its the anti theft relay clicking its probably telling the starter interupt relay to not start. The anti theft relay is towards the back of the area of the ebrake. The starter interupt relay is infront of the shifter or in that area. You will need to remove the center console to get at it.
You can try opening and closing the drivers door with your key...thats where the on-off is for the anti-theft system.
Jim
Jim
