632 ci in a C3?
Old Jan 18, 2011 | 09:59 PM
13brenova's Avatar
13brenova
Default 632 ci in a C3?
Does anyone have any experience stuffing a tall deck big block in a c3 chassis?
Old Jan 18, 2011 | 10:27 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Do a search or shoot a note to Patrick, Pef427. He has a 598" in his '68.
JIM
Old Jan 18, 2011 | 10:44 PM
Ray Y's Avatar
Ray Y
Aren't all of the GM crate 572s tall deck blocks? There are quite a few of those on the forum.
Are you going to try to street that motor?
It should be wicked anywhere you use it!
Old Jan 18, 2011 | 10:59 PM
13brenova's Avatar
13brenova
Yep. The current plan is for a Shafiroff 598 low deck. Just wondering what would be involved to go even bigger.
Old Jan 19, 2011 | 02:11 AM
Street Shaker's Avatar
Street Shaker
You should have no problem at all up to 632 cid it's just a tall deck. For hood clearance you can re-modify motor mounts and gain around 3/8'' in height and you'll be okay or you can build a hood scoop. Stinger scoop modified on top of big block L-88 hood looks nice and you'll gain around 3'' inches clearance. As for headers you'll be better off having them custom built for few more bucks then buying them and have them nice and snugged for better clearance. Jerry Bickel sells some bend weld-up header kits $299 with flanges and you can choose any size primaries and collectors that you want, it would be nice to go 2 1/4'' primaries 3 1/2'' at least collectors for anything that's more then 540 cid.
Old Jan 19, 2011 | 07:03 AM
L88Plus's Avatar
L88Plus
Oil pan may be fun with that much stroke...
Old Jan 19, 2011 | 08:37 AM
ZZ71S's Avatar
ZZ71S
What kind of rear end are you planing on using in this car?
Old Jan 19, 2011 | 05:39 PM
13brenova's Avatar
13brenova
We started on the conversion to a Moser 9" last weekend.
Old Jan 21, 2011 | 01:27 AM
427Hotrod's Avatar
427Hotrod
Patrick (Pef427) lives in Beaumont and has installed a 9" under his car along with a Tranzilla 6 speed. You might be able to ride over and take a look at how it all fits. Headers took a little work on left side but right bolted up fine.
JIM
Old Jan 21, 2011 | 08:41 AM
13brenova's Avatar
13brenova
JIM
I might just do that......
To 632 ci in a C3?
