Good Day Folks, New to the forum and new to the sport. My boys and I are working with a 74 with the 350 J motor. We've redone the brakes, and now it's time to do some motor work. I'm replacing the water pump and alternator, more to be proactive than recognizing any problems. Question is, I want to bypass the heater core, can anyone help with the routing of the hoses from the pump and intake? Thanks in advance for the help.
Just block off the ports at the water pump and the intake manifold with the correct size plugs. I will be doing the same thing as soon as this cold weather breaks.
That's what I did on mine. Been working fine for years and it gets rid of ugly hoses under the hood. BTW, the plugs are pipe thread sizes.
Brass ones, Home Depot or Lowes
Just be sure there's a little bypass hole in your thermostat. And if there's not, then drill one through it. You want some coolant moving past it at all times.
I believe they are different sizes. One is 5/8" and the other is 3/4"
While that's true it's pretty common practice to use one hose for this bypass. This is especially true if you have to make the repair away from you garage. The larger hose is easier by the way.
In any case, I agree with the rest; just use a simple pipe plug. A little sealer won't hurt but isn't totally necessary.
Would it make sense to route a hose from the water pump to the intake?
Both my 73 and my 76 are done this way. It works fine. The 73 has been done this way since dad built the car in 94. The 76 I had to do last summer when the heater core started to leak.
U17 - Good point about the weather. I work at a company just east of the north/south runway. On my way to the office yesterday morning, the thermometer on the car said -12F. But without the humidity, it's a dry heat. Thanks for all the input folks. G
The threads in the holes for the heater hoses are both 1/2 NPT. As far as type of plug, I wouldn't use brass plugs because aluminum and brass have different galvanic potential and will cause corrosion of the less noble metal (aluminum). It's better to use aluminum plugs in an aluminum manifold, and iron pipe plugs in a cast iron water pump.
