Catalytic converter plug???
Old Apr 10, 2002 | 04:54 PM
KB in CO's Avatar
KB in CO
Default Catalytic converter plug???
Anyone that has gutted their pellet type cat converter know where I can get a new plug? I tried to put the old one back in but it fell out on the last drive. I did a quick search on line but couldn't find one.
Would it make a big difference if I went with a new high flow cat on my performance over the factory type cat that I gutted? After doing a quick search it looks like the best one is the car-sound cat. Currently I am just the stock L-48.
Thanks :seeya
Old Apr 11, 2002 | 11:35 AM
KB in CO's Avatar
KB in CO
Default Re: Catalytic converter plug??? (Ken's 78)
Common now. Someone has to have some idea. I know I have read it in other threads but no mention of where to pick up the plug replacement.
:nonod: :sad: :nonod: :sad:
Old Apr 11, 2002 | 01:28 PM
dsilver's Avatar
dsilver
you should be able to get one at the auto parts store. you should be able to use a metal soft plug for engine block
Old Apr 11, 2002 | 01:32 PM
KB in CO's Avatar
KB in CO
Default Re: Catalytic converter plug??? (dsilver)
Duh, :crazy: I didn't even think of that. I was just thinking about one that was exactly the same.
Old Apr 11, 2002 | 07:26 PM
ROD NOCK's Avatar
ROD NOCK
Ken-
GM dealers usta sell a repl, bolt-in clamp style plug. Don't know if it's still avail...maybe just auto parts store cheaper?! :chevy
Old Apr 11, 2002 | 08:35 PM
8T8T2's Avatar
8T8T2
Ken,
I did the same thing on my 80 last year. Removed the pellets but with the baffeling inside the cat. it still seemed like a big restriction. I took a 2 1/4 in. hole saw and a big drill motor with a handle attatchment and drilled out the baffles to make a straight thru shot. To plug the hole I drilled and tapped a piece of thin metal[1/4 x 20]longer than the diamater of the hole but narrow enough to be inserted with the cat. up-side down and used what is called a elevator washer[over sized thin washer] on the outside with a 1/4 screw to seal hole.
Just lately for emissions I replaced it with a direct fit car sound cat.
To Catalytic converter plug???
