What determines an engine's redline?
Old Jan 27, 2011 | 09:50 AM
nate99's Avatar
nate99
Default What determines an engine's redline?
Just a question for the experts.
I've got a 290HP GMPP 350 crate engine that will serve as a mule motor during my restoration that has a recommended redline of ~5200 IIRC .
I intend to upgrade the heads and cam eventually, and it got me thinking of how high do I want I want to spin the thing?
As I understand it, redline is limited mostly by the valvetrain, but I did not know what most after market heads (I'm thinking AFR's) and hydraulic roller lifter cams were good for.
I'm not going to spend much time north of 5500 in any case, but was curious.
Old Jan 27, 2011 | 10:39 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
The redline may be limited by valve train characteristics for sure. But definitely it's related in Hot Rodder's terms anyway, by the RPM at which the whole system stops increasing HP.
If your max torque is for instance, at 5250RPM and max HP is at 5500, it's just a waste of gas and time to rev any higher than either of those numbers.
Old Jan 27, 2011 | 10:42 AM
Solid LT1's Avatar
Solid LT1
Valvetrain, exhaust and induction system in about that order.
Old Jan 27, 2011 | 03:17 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
When she blowed up real good you are well past the engines redline
Old Jan 27, 2011 | 03:25 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I think its also related to the material of the crankshaft (orged vs cast) and how its connected to the block (2 vs 4 mains).
Old Jan 27, 2011 | 03:56 PM
LB66383's Avatar
LB66383
I seem to remember that that motor has powdered metal connecting rods. That would be a limiting factor in how fast to spin it, and how much horsepower you want to try to get out of it.
Old Jan 27, 2011 | 04:38 PM
nate99's Avatar
nate99
Hoping to avoid that level of definitive confirmation.
I think this gets to what I was asking better than the way I phrased it earlier. If we suppose that the valve springs/retainers are the limiting factor, what is the next thing that would keep you from revving higher and where would the line be?
FWIW, the engine has four bolt mains, nodular crank, powdered rods and cast aluminum pistons. I'm eventually wanting healthy low end, so I'm not looking to rev the thing to the moon in any case, but just wondered where you start getting in to trouble with stock-ish quality bottom end hardwear.
Thanks.
Old Jan 27, 2011 | 04:47 PM
alswagg's Avatar
alswagg
In the marine industry, the pre Vortec motors had a consistant WOT of 4,500 rpm. The WOT rpm was increased to 5,000 rpm on 1st generation Vortec which was around 98 and then again another increase in WOT rpm to 5,500 rpm in 2004. These are for Small block engines. The standard 496 has a WOT rpm of 4,600 and the 496 HO has a WOT rpm of 5,400 rpm. We routinly run these motors for hrs at a time in the 4,000 to 5,000 rpm range. The valve train is all roller lifters but still stamped steel rockers. Al
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
The suggested safe max rev limit for a given reciprocating assembly is commonly calculated from how high an average piston speed the parts are considered capable of sustaining. For a 350, 5200 RPM only produces a average piston speed of 3016 fpm with a max of 4953 fpm. Mild by true high-perf engine standards IMCO, but you'll need to account for the quality of bits and assembly of your engine in deciding how far to push it.
As for how high it will actually wind, that's a far different matter determined by many variables.
Old Jan 27, 2011 | 05:05 PM
Belgian1979vette's Avatar
Belgian1979vette
Usually the valve train is the first thing to go when being overreved.
What destroys the engine next is vibration.
Last is the G-forces on the rods and crank.
With your engine i'm pretty sure, the valve train is the limiting factor to go higher.Next is intake tract, cam, then crank and rods.
Old Jan 27, 2011 | 06:28 PM
nate99's Avatar
nate99
Interesting stuff, thanks.
Old Jan 27, 2011 | 06:54 PM
tgcattle's Avatar
tgcattle
I have that motor and it pulls up to 5500 rpm. I don't go past that
Old Jan 27, 2011 | 11:34 PM
hwcoop's Avatar
hwcoop
One thing is for sure...you don't want to rev it this high!
http://www.youtube.com/watch?v=26X_s28ilYs
Old Jan 27, 2011 | 11:59 PM
joewill's Avatar
joewill
http://en.wikipedia.org/wiki/Redline
Old Jan 28, 2011 | 12:01 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Your wallet!
JIM
Old Jan 28, 2011 | 12:15 AM
l88rocket's Avatar
l88rocket
when the motor feels like its stopped pulling or lays down thats a sign, or when the rods leave the block..
Old Jan 28, 2011 | 08:37 AM
nate99's Avatar
nate99
Originally Posted by joewill
Crazy that a regular production 600cc motorcycle engine will spin to 16.2K.
To What determines an engine's redline?
Old Jan 28, 2011 | 09:14 AM
jackson's Avatar
jackson
FYI ... GM powder metal rods are good but they have a limit too.
Anecdotal limit:
Lotsa regional CT racers run GMPP crates x602 & x603 (zz4) ... all have the very
same GM x688 PM connecting rod as that GMPP 350/290 crate should have.
Local feller (usually runs a built motor) ... but took opportunity to run a special new years day crate motor race at Dillon motor speedway. His car runs rear gear that typically puts him about 6800-7K at end of straights just before he lifts.
He left that gear in when he showed up with x602 crate. He was warned repeatedly during practice to change gear ... crate revving too hi ... he didn't heel. Crates usually geared there to top out about 6200. Oh well ... his was 6800-7K when a rod came loose. Motor's disassembled & I looked it over last week. Total loss. A couple rods & pistons & one head maybe OK ... block & remainder could bring about $12/hundredweight. At 6200 they rarely have a problem, but not so good much beyond that. Now keep in mind this is a repeated, hard, on-off-on-off cycle within every 20 seconds ... not a street car. YMMV.
FWIW ... x688 rod broke just about mid-beam ... Not just above big end.
Old Jan 28, 2011 | 09:46 AM
nate99's Avatar
nate99
Anecdotal limit:
Interesting. Mine might go to the strip one day, but I live in a pretty densely packed suburb, so any blasts above 5000 rpm are going to be few and far between. I'll be surprised if any occasional hooliganism in which I could theoretically partake would tax the bottom end.
Old Jan 28, 2011 | 12:31 PM
Rich's'78's Avatar
Rich's'78
I've got a 290HP GMPP 350 crate engine that will serve as a mule motor during my restoration that has a recommended redline of ~5200 IIRC.
I'm no expert, but I would stick to 5200 rpm with cast pistons. An old Hot Rod article wanted to she what a SBC would do with a buildup and the rod pulled the wrist pin out of the cast piston at 6500. Hence, redline was 6000, but maybe not for long ......
