Is 93 octane enough?
Old Apr 10, 2002 | 10:11 PM
TD-Machines's Avatar
TD-Machines
Default Is 93 octane enough?
Is 93 octane enough? For my 1970 350 300 10.25 compression. or should I use an octane booster? And if so what one do you recommend? :cool: :chevy
Old Apr 10, 2002 | 10:17 PM
xfactor974's Avatar
xfactor974
Default Re: Is 93 octane enough? (td-machines)
You'll be ok. Watch the timing.
Old Apr 10, 2002 | 10:20 PM
joe73vette's Avatar
joe73vette
Do you have an owners manual? The one for my 73, which is only 8.5:1 compression, requires 91 octane. Do you hear detonation (pinging) under load? You can retard the spark a little if you are on the edge, or fool with the vacuum advance if you are handy with a distributor. Look at the plugs, are the electrodes eaten away by preignition? Is the porcelain broken? If all of the answers are "no" then 93 octane is probably OK. FWIW, I used 93 in my 69 with the same motor, and didn't have any problem, but I was young and naive then, too. Joe
Old Apr 10, 2002 | 11:08 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I think that you shouldn't have any problem with a 10.25 : 1 compression.
The 383 stroker engine on my previous 69 Vette had a 10.8 : 1 compression and I ran with 93 octane + 2 bottles of octane boost (108). Sometimes I ran without octane boost and the engine would run ok. However - everytime I used Chevron gas - the engine started dieseling. This must have something to do with the additives they add to their gas...
Olivier
Old Apr 10, 2002 | 11:27 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: Is 93 octane enough? (GrandSportC3)
Remember this...
1. Any pining is bad
2. Older engines require more octane than new engines due to their design, so 93 may not be enough...
Old Apr 11, 2002 | 12:24 AM
Carl in LA's Avatar
Carl in LA
Default Re: Is 93 octane enough? (427V8)
Its all relative... The 93 will be enough with the timing cranked back so far you leave horsepower on the table... keep the timing up, dump in the octane booster, and let that baby fly!!! I also bet there are situational tuning tricks like making the high speed mixture a little richer, using cooler plugs, or even something like ceramic coating the internals in the combustion chamber to spread out the heat.
Old Apr 11, 2002 | 01:56 AM
shawn_cake's Avatar
shawn_cake
If you ping or run on use Lead Supreme 130 by Kemco Oil in Lehi Utah.
It is almost completely tetraethyl lead. Look at their website:
http://www.kemcooil.com
:cool:
To Is 93 octane enough?
