hella h4 h5006
Old Jan 28, 2011 | 04:36 PM
rugerm44's Avatar
rugerm44
Default hella h4 h5006
Are these for low and high beam.like to know before I order them.thanks
Old Jan 28, 2011 | 05:21 PM
72LS1Vette's Avatar
72LS1Vette
Looks like you need the 5006 for low/high and the 5001 for high beam.
Rick B.
Old Jan 28, 2011 | 05:27 PM
rugerm44's Avatar
rugerm44
Thanks.know any good sources.can you get away with the e code version in the states.
Old Jan 28, 2011 | 06:59 PM
72LS1Vette's Avatar
72LS1Vette
If you just do a google search on your original title - hella h4 h5006 you will find lots of vendors.
Rick B.
Old Jan 28, 2011 | 07:45 PM
rugerm44's Avatar
rugerm44
I found a couple through amazon.they have to better than the sealed seems.they are like driving with a flash light compared to the newer cars.
Old Jan 28, 2011 | 10:43 PM
zwede's Avatar
zwede
I have for 15 years.
Old Jan 29, 2011 | 12:15 AM
Wrencher's Avatar
Wrencher
I love 'em. Had them in my BOSS for years and they are VERY good headlights.
Hans
Old Jan 29, 2011 | 02:14 AM
eagle275's Avatar
eagle275
I use these, and also H1 conversions with good glass lenses,and good H1 light.
http://www.autobahnpower.com/products.asp?recnumber=749
http://www.autobahnpower.com/products.asp?recnumber=748
This guy knows his lights!
Daniel Stern : www.danielsternlighting.com
Old Jan 29, 2011 | 07:24 AM
jb78L-82's Avatar
jb78L-82
I have had mine (hellas) since 1986-never a problem unless you live in a communist state like CA (My mom's BMW with the Hellas failed a post accident inspection in San Diego after the repair with the Hellas-She had to remove the 4 Hellas, replaced with sealed beams, and put back the Hellas after the inspection-totally ridiculous!)
I agree that the Cibie/Marchal (Daniel Stern lighting) are probably the ultimate in Lens design for halogen headlights BUT I am not so sure that they are worth a 50% price premium over the Hella Euros.
Old Jan 29, 2011 | 05:15 PM
rugerm44's Avatar
rugerm44
Went with the Hellas.they are good enough for aircraft.
Old Jan 29, 2011 | 06:19 PM
Mashman's Avatar
Mashman
I went with these - and it's like night and day from the old sealed beams.
http://www.bigrigchromeshop.com/Merc...Category_Code=
They are metal and glass, and I'm happy with the quality. They come with some bulbs, but I didn't try the lights with them, I went strait away and erplaced them with some Hella bulbs.
This is probably the best $70 I've spent on the car so far. I only replaced the hi/lows, as I didn't really have a problem with my highbeams, and I have even less of one now.
Old Jan 29, 2011 | 06:49 PM
eagle275's Avatar
eagle275
That will work.
Old Jan 30, 2011 | 12:56 AM
eagle275's Avatar
eagle275
Also, here is a place I have had good success with, pretty reasonable too, have some of the best bulbs you can find -
http://store.candlepower.com/ca5quhahebun.html
Old Jan 30, 2011 | 07:55 AM
jb78L-82's Avatar
jb78L-82
Just a word to the wise about headlight lenses in general-the most important aspect of the light output is the quality of the headlight lens, not the halogen bulb necessarily. The art of optics is basically the science of physics. Contrary to what you would think, all headlights with a glass/plastic lens and a shiny reflector do NOT put out equivalent light. The lens is critical in maximizing the light output in a focused pattern according to its application-think of a lighthouse lens which are highly polished reflectors with lead crystal lenses going back hundred's of years using candles in the beginning and they were very bright and worked even back then.
How do I know the differences in halogen car headlights? I started using Euro halogens in 1978 when I was in high school with my 73 Nova SS-7 inch round Hella H4 bulbs-way way before these lights were even remotely legal in the US. Over the years I have had those lights, Marchal on a 72 Caprice quad lights, Cibie, and since 1983 on the 78 Corvette Hella Euros-55watt/100 watt low beams and 100 watt High beams (I use a relay on the highs to keep the amperage off the headlight switch). These lights are truly incredible even today and are like having portable daylight on the front of the car. I actually had a set of 7 inch glass H4 halogens (no name) from JC Whitney 20 years ago and they are NOT the same as the other manufacturers by any stretch-you get what you pay for like with most things in life! Hope that helps!
Old Jan 30, 2011 | 11:05 AM
rugerm44's Avatar
rugerm44
Thanks.the set I bought ran me around 200.they are the e spec lenses.I also bought an upgraded harness from summit racing.just have to figure out how I want to run power to the battery.
Old Jan 30, 2011 | 12:53 PM
noonie's Avatar
noonie
Cibie = daylight
Old Jan 30, 2011 | 01:15 PM
Paul L's Avatar
Paul L
Are relays necessary?
To hella h4 h5006
Old Jan 30, 2011 | 05:37 PM
zwede's Avatar
zwede
For anything above a standard 60/55W you should run relays. For a 60/55W it is optional, but relays will make the lights a bit brighter.
Old Jan 30, 2011 | 08:03 PM
jb78L-82's Avatar
jb78L-82
With my 78, I was not able to run the 4 Hella Euro lights even with 55/60 watt low bulbs and 55 watt high beams since the amperage draw will trigger the circuit breaker in the headlight switch. I run the lows on the standard C3 circuit and the 100 watt H1 bulbs off of a relay. The 78 came with sealed beams which draw about 35 watts each or 140 watts for 4 headlights which is what the headlight switch relay was designed for thus the need for a relay when running higher wattage/amperage. I have not experienced brighter lights running a relay versus not although that is a claimed benefit-I have run many headlight/foglight relays over the years but have always run the relay primarily to take the amperage off of the switch so as to not overload it.
Old Apr 14, 2023 | 05:54 PM
81C3BUILT's Avatar
81C3BUILT
I agree with everything you say except for the communist comment, you have obviously never lived under true communism because you have no clue! And 2nd, can we as Americans get thru a day on a corvette tech site without having the Angry American voice his disdain for this the best country on earth. i suggest you go live in China for a year and then give me your opinion of California...I have 2 family members buried at Arlington, two great uncle Dough Boys WWI and a Vietnam uncle...Shame on you for not appreciating what you have, and have been givin, by my family's blood!!!!! JUST TALK CORVETTES, or get on a stump with a megaphone in your home town, and run for office!
