Need help with rear rotor
Old Jan 28, 2011 | 10:08 PM
tantalumgirl's Avatar
tantalumgirl
6th Gear
Default Need help with rear rotor
I just bought my first Corvette, a 1980. We decided to do the brakes soup to nuts, new master cylinder, ss lines, new calipers. The first 3 wheels were a breeze, but when we got to the right rear, we found that it was the original riveted rotor; the brakes had never been done. We spent two days pounding on it before we gave up. Ended up replacing the whole trailing arm assy and rotor with a new one from Duntov. We opted for the non-riveted version because it seemed more sensible, but now I'm wondering if we made a mistake. The rotor goes on easily enough, but it just doesn't seem to be seated correctly. When the caliper is bolted on, it seems like it's at an angle. What can the problem be?
Old Jan 28, 2011 | 10:20 PM
wombvette's Avatar
wombvette
I don't know exactly what you mean by when the caliper is bolted on its at an angle. Whats at the angle, caliper or rotor?
But, you should make absolutely sure thats a rear rotor and not a front or the pads will not fit.
Old Jan 28, 2011 | 10:43 PM
tantalumgirl
6th Gear
It doesn't seem like the rotor is seated on the hub correctly, and the caliper is a little cocked. The front pad is lower than the rear pad. The center of the left rear hub sticks out more than on the new one.
Old Jan 28, 2011 | 10:54 PM
vettehardt's Avatar
vettehardt
Tighten your lug nuts against the rotor to seat it (may need a spacer between lug and rotor) and then look at your alignment. The lugs are what holds the rotor against the hub, sandwiched between your wheel and hub.
Old Jan 28, 2011 | 10:56 PM
tantalumgirl
6th Gear
Thanks, will try that tomorrow.
Old Jan 28, 2011 | 11:00 PM
wombvette's Avatar
wombvette
Still sounds like the wrong rotor. Remove the pads and bolt everything up using the lug nuts to hold the rotor tight. Turn the lug nuts around backwards to protect the rotor. Then take a look at how the rotor is centered in the caliper. My bet is it will be way off to one side.
Old Jan 28, 2011 | 11:05 PM
tantalumgirl
6th Gear
Ok, thanks for the advice, will try tomorrow and let you know what I find. Sad to think Duntov might have sent the wrong part.......
Old Jan 31, 2011 | 08:38 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
Easiest way to check if it is the correct rotor would be to check for parking brake adjustment holes.
Old Feb 3, 2011 | 12:55 PM
tantalumgirl
6th Gear
We finally got back out to the garage. It definitely is a rear rotor, not a front one. We took the left rear rotor off and tried to put that on the right, but it doesn't fit either. My boyfriend now thinks the rotor might possibly be for a different model year?? I got a message from someone at Duntov who saw this thread, he sent his phone number and told me to call if we can't figure it out. Now that is great customer service......
Old Feb 3, 2011 | 09:26 PM
wombvette's Avatar
wombvette
Same rotor from 65 to 82, so thats not likely. One or two things are happening here. One the rotor is wrong (front-rear) or two, the caliper mount is bent. If you will do the test that I described before, you will determine which.
Old Feb 3, 2011 | 10:13 PM
vettehardt's Avatar
vettehardt
If the rotor from the left side fit on the left side, but the same rotor doesn't fit on the right side, there must be something wrong with the right side and not the rotor. It could be the hub screwed up not mounting the rotor correctly, or it could be the caliper bracket is bent like wombvette said.
Old Feb 4, 2011 | 10:31 AM
tantalumgirl
6th Gear
Here is the latest theory. Last night we laid both rotors on the floor side by side and measured everything. The ID of the new rotor is about 1/8" less than the old one, just enough to keep it from seating completely. It's just catching the pads, which are dialed all the way in. The rotor looks like it was rough machined, the inside surface is not very smooth. I'm thinking of having it cut locally vs paying to ship it back. Also tried the left rotor on the right side again, it seems to be catching on one of the lugs, and changing the rotor position doesn't help. I'm not worried about it, the old rotor fits the old trailing arm, I just need to get the new rotor to fit.
To Need help with rear rotor
