My first Vette was a '77...
Turned out easier to just ut in a crate motor than trying to soup-up a high miles motor that was never built for real HP...
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Originally Posted by USMuscle
I just picked up a 77 L82 Vette. She is one sweet ride, but she is bone stock and a little slow for my liking!
What are some common mods that will boost the power in this vette for a good value. Best return on investment for a smaller budget? Cam, intake, etc?
I have a 77 and for the money you can toss at it to try and get the hp out of that l82.. you can just put a zz4 in it and be done with it.. you go from a 160+- hp car toanything from a 260hp +..and with a few other bolt ons you can get a little over 300.. and that is more than enough...
If I were to do it all over again. I would get the zz4 and do the lt4 hot cam package on the car before i installed it.. with that cam and a little porting of the zz4 heads you can easly be over the 300 mark.....
so pull that # matching motor and save it.. ill be rebuilding my #matching motor and just setting it to the side......good luck
Will an LS1 out of a C5 bolt right up to the tranny on these? How much power will this tranny hold safely without bulletproofing?
crate motors are the way to go if youre not the type to get the satisfaction from a job well done ( or job gone horribley bad) lol. schafiroff, cnc-motorsports, gm performance all good companies to do bussines with & the only limitations are you bank account. but if your looking to get a few more horse's out of what you have, first do a compression test, to verify that you still have decent compression as not to through good parts at a fading bottom end. with the right heads, camshaft, intake & headers with true dual exhaust it's fairly easy to get 400 horse all by 5800 rpm. the two bolt bottom end will sustain 5800 rpm. afr's web site has dyno'd combo's for small block chevy. just my 1.5 cent's.
If you're like me and have a limited budget after a Vette purchase:
Free: advance the timing at the distributor, set the idle as low as possible without dying
$100s: full length headers, 2 1/2 exhaust and high flow cats if needed, rebuild carb, new coil, dist cap and wires
$1000s: aftermarket heads
In that order!
Or do what my buddy did and put it all on a credit card:
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
start with a real tune up and make sure everything is working correctly especially with the distributor, its not unusual for the advance mechanism to be frozen so you have no advance what so ever....the TH350 will handle lots of power but you run out of top end gearing thats why the overdrive trans are so popular
The stock cam and intake are good on the L82. I agree with Bob, first rebuild and recurve the distributor for 36 degrees by 2,800-3,000 RPM. If you want to advance the cam 4 degrees for some bottom end you can do that too. A good dual exhaust with or without headers. New heads with 64cc chambers to get some compression to make some power.
the l-82 short block is identical to a 72 lt-1 except the cam. distributor, Carb, and exhaust go a long way on that engine cam and heads its equal to a zz4. why don't people understand an l-82 is any excellent foundation to build on forged crank forged rods forged pistons, your beloved zz4 has powdered rods and hyperutectic pistons.
In that order!
3: headers and dual exhaust (will cost some, but worth it)
4: Maybe.....pull the heads and replace head gasket with .015 shim gasket, which will bump compression about 1/2 a point. (I'm not sure if this last point would really be worth the hassle, but it wouldn't cost much, and that big L82 cam screams for compression)
Do the first 3, and that car will rip!!!
Scott
Mark... edelbrock.com search Power Package and Power Package Top End Kit. There are several different combos, and levels of complexity. You can pretty much order a killer top end in a single box, delivered to your door.
You have several devices connected to you intake and carb that control accessories like brakes, distributor, head lights, and transmission. A leak in any of these rubber vacuum lines can cause engine to run irregular. So make sure all the vacuum sources on your carb are either connected or plugged/capped. Also check you rubber lines to make sure there are no cracks.
I rebuilt my distributor and set timing as described above and was very surprised how much better the car performed. As stated, check the simple things first. These were mid-70s cars and they were all dogs in my book. Your L-82 bottom end has good parts in it and strong enough to handle some pretty decent HP, assuming your compression and leak down test look good. You have to weigh whether you want to save that motor until having matching numbers becomes more important in the future of the rubber bumper cars or just upgrade what you have.
Keep asking a lot of questions and read as much as you have time to here on CF. There is a ton of information here that will help you make the decisions that are right for you. Come up with a plan and we'll be glad to critique it for you.
It seems there is no general consensus on how to generate more
horse power.
The first thing I would do is pick up a copy of
"How to Build Max Performance Chevy Small Blocks on a Budget".
It provides 10 engine builds that produce good HP.
The L-82 has all the compression you need for 300-350 HP.
The heads are OK also. If you really want to change them
go for a set of Cast Iron Vortecs. They flow very nicely and are
the most cost effective choice. Others will say you must go aluminum.
All things being equal the iron head will out perform the aluminum.
I like the Edelbrock Performer RPM Manifold with a 750 Holley.
If you chose Vortec heads make sure you get the correct intake.
Your L-82 intake will not bolt up.
I like the LT-4 hot cam. In order for you to use it your block will
need to be machined. For 300 - 350 HP a 1970 LT-1 cam would be fine.
Last but not least get a set of equal length tube headers.
Make sure you select headers with 1 5/8 primary tubes. Anything larger will adversely effect your low end torque.
