Installing Aluminum Heads
Old Jan 30, 2011 | 12:25 PM
78pace's Avatar
78pace
Default Installing Aluminum Heads
Good afternoon,
Edelbrock instructions call for an oil/moly mix for head bolts prior to install. Could someone explain what moly lube to use and percent of each to mix.....
Thank you
Old Jan 30, 2011 | 03:12 PM
l88rocket's Avatar
l88rocket
I use Arp bolt grease. some auto parts store carry it
Old Jan 30, 2011 | 04:51 PM
noonie's Avatar
noonie
Those are generic instructions for all engines not just chevy.
Most of sbc bolts go thru to the coolant and a sealer should be used instead on ALL the bolts to get even torquing.
http://www.permatex.com/documents/td...tive/56521.pdf
Read this from ARP
http://arp-bolts.com/pages/technical_installation.shtml
Old Jan 30, 2011 | 05:38 PM
alswagg's Avatar
alswagg
The last complete bolt set I bought for a Small block from GM was under $29.00 for a complete set. Plus the bolts come presealed, However the head of the bolt needs to be lubricated to resist torque friction while tightening. At $29.00 for Factory bolt set pre sealed, it is hard to beat, especially for the amount of time it takes to remove the old sealant. Good luck Al
To Installing Aluminum Heads
