Help with part please
Old Jan 30, 2011 | 10:42 AM
psycho dad's Avatar
psycho dad
Default Help with part please
There's a vacuum fitting that screws into the intake right behind the carburator, two vaccum tubes attach to it. One of the nipples snapped off when I tried to slide the tube over it. What is this fitting called, and where can I get a new one? I did a seach of vacuum fittings at Summit but didn't see one. Thanks, - Jay
Old Jan 30, 2011 | 10:58 AM
rugerm44's Avatar
rugerm44
Try zip Corvette.I think that's where I bought mine.
Old Jan 30, 2011 | 11:08 AM
dannyman's Avatar
dannyman
EGR vacuum fitting?
Old Jan 30, 2011 | 11:14 AM
Alan 71's Avatar
Alan 71
Hi Jay,
They're in the intake manifold section, intake fittings, in the ZIP catalog.
They're made with various numbers of nipples and with the nipples in various positions.
There are pictures so you'll know which part number to order.
Reards,
Alan
Old Jan 30, 2011 | 11:20 AM
Paul L's Avatar
Paul L
It's simply called an intake manifold vacuum fitting. The pic shows a 1974 version. I believe you are looking for a two-port version for a 1976 with automatic. I have checked several vendors' catalogues and strangely a two-port unit for a 1976 is conspicuous by its absence. The one-port version is there for manual transmission cars but....I see 1974-75 as seen in the pic and 1977- but not 1976! Bizarre. But surely another year can be adapted.
Old Jan 30, 2011 | 11:25 AM
psycho dad's Avatar
psycho dad
You're right, it's not listed. One port has to be straight up to fit a shaped tube.
Old Jan 30, 2011 | 11:41 AM
Paul L's Avatar
Paul L
Does it look like this?
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Old Jan 30, 2011 | 11:55 AM
psycho dad's Avatar
psycho dad
that's very similar
looks like it will work
Old Jan 30, 2011 | 12:49 PM
Paul L's Avatar
Paul L
Or you can go with something like this and just route the rubber vacuum hose a little differently.
http://www.volvette.com/EN91F.html
Old Jan 30, 2011 | 02:09 PM
psycho dad's Avatar
psycho dad
I may be able to get a used on from a local corvette shop, I';; try that before I start improvising.
Thanks guys for all the useful input, I couldn't do this without the help of my Corvette brothers.
Old Jan 30, 2011 | 06:56 PM
Paul L's Avatar
Paul L
I hope you sort things out! I am still curious as to why the 1976 is a different creature. I had hoped that Ernie from Willcox would jump in.
To Help with part please
