Broken U Joint / Side Yoke End Play - Pics
Car: 1970 350/350hp 4spd, comp 240/246 cam, ported heads, 650 speed demon
I recently snapped a u-joint in half during a hard 1-2 shift. The disconnected half shaft bent a strut rod, put a nice crack in the fiberglass tub, sheard the bolts off in the diff side yoke, and generally wreaked havoc.
While pulling the differential to removed and repair the side yoke, I want to make sure everything is in tip top shape. Below is a shot of my diff and the side shaft end play, 0.022". I have read this is acceptable end play, is that true? The center pin doesn't seem to be worn and there is no visible mushrooming of the side yoke. What else should I check while the diff is out and how should I go about it (test posi, backlash, etc)?
The car previously made a clunk when going from reverse to first. I suspect this may have the cross-member bushings moving around, but I want to insure it was not the diff before I bolt her back together.
At this point I only plan to do the following:
Install 5-799x Spicer U Joints
Finish drilling out sheared bolt and tap new threads
replace yoke seals
replace yoke bolts
Is my supposed factory yoke worth saving? I have heard the standard and HD replacements are weak. The Tom's yokes look nice, but are out of my budget. All my pennies are going towards a frame off restoration in the coming months and I don't want to over do this diff project.
What else to test/fix/install?
How much radial movement is allowed on the yoke? What is the method for measuring?
Remove carrier, clutch packs and spiders.
Install one clutch pack with gear. Install ONE spider and cross shaft. Jam pry bar/big screwdriver between side gear and cross shaft (putting preload on clutch pack). Feel the spider gear play. Add shims behind clutch pack until play is almost gone. You only want about 0.001", so barely detectable play. Repeat for other side.
Also, a tip is to leave the preload springs out. It decreases the shock load on the spiders when you punch it. The posi will still work without them.
Did you check the end play of the right side yoke? The splines on the right yoke should look like those on the left, but it looks like they're missing - perhaps the yoke was already pulled?
Should I be replacing the clutch discs during the shimming process? What is the best source for shims and disc?
http://www.lbfun.com/warehouse/tech_...nt_Rebuild.pdf
http://www.lbfun.com/warehouse/tech_...osi_Tuning.pdf
