arp main studs 400 sbc
Old Jan 31, 2011 | 08:08 PM
tgensel's Avatar
tgensel
Default arp main studs 400 sbc
anyone know the right part number for a 2 bolt 400 ?
Old Feb 1, 2011 | 08:54 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
This is cut straight out their catalog. The only 400 specific listing is for 4 bolt blocks. I would assume they use the 2 bolt sets for either the large or small journal SBC. Depending on what type of nut you want the numbers are below.
All 4 bolt mains
400 cid with windage tray 234-5606
400 cid with windage tray & 3.0˝ outer studs 234-5607
400 cid with splayed cap bolts & windage tray 234-5605
Two Bolt main stuff
Large journal (hex) 134-5401
Large journal (12 pt nuts) 134-5403
Large journal with windage tray (except LT-1 & LT-4) 234-5501
Large journal with straps (F & R caps) 234-5503
Small journal 134-5402
Small journal with windage tray 134-5501
Old Feb 1, 2011 | 02:48 PM
tgensel's Avatar
tgensel
Thanks much
To arp main studs 400 sbc
