Power Steering pump mount
Old Feb 2, 2011 | 10:10 AM
Muffin's Avatar
Muffin
Default Power Steering pump mount
Son has a 71 vert. When the engine is reved the slightest bit you can see the PS pump flex inward. Seems to me there is a bracket/brace missing. My plan is to install one of these:
http://www.ecklers.com/catalogsearch...cket&x=30&y=12
I'm guessing the brace bolts to the PS bracket then to some point on the engine. Anyone have a clue where on the engine? The car is not here, I gotta go to it,Orlando, this weekend, would like to take all the pieces and parts I need with me.
Thanks C3 gurus.
Old Feb 2, 2011 | 10:24 AM
wombvette's Avatar
wombvette
Thanks C3 gurus.
Motor mount bolt.
Old Feb 2, 2011 | 11:37 AM
Muffin's Avatar
Muffin
Originally Posted by wombvette
Motor mount bolt.
Interesting, thanks.
Old Feb 2, 2011 | 12:17 PM
Kevin68's Avatar
Kevin68
Do you mean that the PS pump moves relative to the frame or relative to the engine? The PS pump is mounted low on the driver's side of the block so if the PS pump and engine are moving relative to the frame, I'd look at the motor mounts. If the PS pump moves relative to the engine, I'd look at the mounting bracket. It may be as simple as a loose bolt(s). Does the belt stay tight when you rev the engine? I'm assuming the PS pump otherwise operates normally.
Old Feb 2, 2011 | 04:39 PM
Muffin's Avatar
Muffin
Relative to the engine, you can see it flex toward the balancer.
Belt does not stay tight, will loosen to the point it slides on the PS pump pulley. With the engine off belt is very tight. There are no loose bolts.
I am concerned the present bracket has metal fatigue from flexing for at least 6 years that I know of. I will change out the bracket and add the brace that runs to the mount bolt. Best look at the belt too, may be burned from slipping so much.
Old Feb 2, 2011 | 05:51 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Here's a pic I had, maybe it'll help.
Picture was taken from below.
Behind the 2 hoses you can see the support with the one end bolted on using the motor mount bolt. The other side of the bracket is sandwitched between the cradle bracket under the pump and the block.
Without this support bracket, you'd also have NO place for the adjusting bolt as the curved slot in the support is for the adjustment.
Is it possible the pump simply isn't tight because of a lack of an adjustment bolt?
Old Feb 2, 2011 | 09:54 PM
Muffin's Avatar
Muffin
Thanks for the picture. The belt is tight with the engine off. With the engine running when the steering wheel is turned loading the pump the pump bracket actually bends. Bends enough so it can be seen. The brace that runs to the motor mount is not there. I am wondering just what kind of mount is there. May not be OEM to the Corvette at all. I'll install the correct one which should fix the problem.
Old Feb 3, 2011 | 10:27 AM
Kevin68's Avatar
Kevin68
My after market backet does not have a brace to the motor mount. There are (on my 68) two 3.5" bolts that go through the bracket and directly into the block (the lower one is inside the sleeve on the picture above between the balancer and the block). There are two pivot bolts directly opposite each other on the lower front and rear of the pump that attach the pump to the bracket (sliver bolts in the picture above), and one bolt on top of the pump that has a long opening that allows you to tighten the belt.
Be careful ordering replacement brackets, because the wrong bracket will result in some frustrating alignment issues.
I'd also note that in the picture above the PS belt looks like it is in the third balancer groove, where I think in the standard set up it's in the second groove. You should check with your AIM for the belt routing. Is your motor original?
Old Feb 3, 2011 | 12:59 PM
KapsSA's Avatar
KapsSA
If you look at this link for OEM style small block brackets, used from 63-82, you'll notice there are no provisions in the lower cradle bracket for any type of adjustment. In the support bracket you can see the curved slot.
I guess one could try tightening the 2 pivot bolts in the cradle bracket but I wouldn't count on it staying adjusted.
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
And in my pic above, you'll notice 3 belts in the crank pulley, AC,alt, and PS. Every small block application I've ever seen has the ps belt in the forward most pulley groove.
To Power Steering pump mount
