Head Install Question...
Old Feb 6, 2011 | 07:43 AM
DO2G's Avatar
DO2G
Default Head Install Question...
Just curious.....Do you guys install in the spark plugs into the heads prior to placing the heads on the block?
Old Feb 6, 2011 | 08:17 AM
Casey71's Avatar
Casey71
I don't, but I'm not a big time engine builder..
Old Feb 6, 2011 | 09:14 AM
Gordonm's Avatar
Gordonm
I don't but what does it matter. It makes no difference. I usually put in an old set to paint the motor.
Old Feb 6, 2011 | 09:24 AM
DO2G's Avatar
DO2G
Thanks guys....I thinking now it might be easier to bolt in the new heads without the plugs in....
Old Feb 6, 2011 | 11:02 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Nope. You can break plugs that way. I always install heads without plugs.
Timsride's Avatar
Timsride
I never install plugs that are going to be used when running as they can be damaged when installing headers and such.
Old Feb 6, 2011 | 02:55 PM
DO2G's Avatar
DO2G
Thanks guys
To Head Install Question...
