Half-shaft refinish
Old Feb 6, 2011 | 04:00 PM
wheatpj's Avatar
wheatpj
Default Half-shaft refinish
I’m going to have the half-shafts out while I replace the u-joints. I figured I would pretty them up while I have them out; they are awful rusty. I’m looking for suggestions regarding techniques, paints, correct finish, etc.
Old Feb 6, 2011 | 04:43 PM
Kahle76's Avatar
Kahle76
Old Feb 6, 2011 | 05:07 PM
Alan 71's Avatar
Alan 71
Hi,
The half-shafts are made of a piece of extruded steel tubing with forged ends for the universal joints. The forged ends were welded to the tube. All the components were originally 'natural'. The tube was quite 'bright' when brand new but rusted quickly. There were lines running the length of the tube from the extrusion process. There was a darkened 'heat zone' on the ends of the tube from the welding process.
There are lots of ways to refinish the half-shafts depending on the look and the serviceability you want.
I have semi-gloss clear on mine.
Regards,
Alan
Here's the 'before' picture. RUST
'After' The one on the right shows the actual finish most accurately.
Old Feb 6, 2011 | 05:10 PM
Duke94's Avatar
Duke94
Correct finish is no finish. Tubes are bare steel and ends are cast iron. I think Eastwood sells paint that is suppose to look like steel and cast iron.
Gary
Old Feb 6, 2011 | 05:13 PM
joewill's Avatar
joewill
my book calls for 'bright natural finish' if you care about it looking like typical factory appearance..
I like black or gray powdercoating.. it makes them look nice!
Old Feb 7, 2011 | 12:24 PM
Rebelrob's Avatar
Rebelrob
Mine had a nice coat of rust on them. When I pulled my rear end for a gear swap and new u- joints, and a rebuild, a good cleaning was in order. I sanded the crap out of them to get most of the rust off and then painted them. It's not original color, but should keep the rust away. Looks so much cleaner now. Added 6 Spicer u-joints. Ensure u put your driveshaft back on the same way u took it off, might cause it to not be balanced correctly.
[IMG][/IMG]
[IMG][/IMG]
Old Feb 7, 2011 | 04:24 PM
redman76's Avatar
redman76
St. Jude Donor '09
Nice looking half-shafts guys. I wire brushed and hit mine with POR-15 then gloss black top coat.
Old Feb 7, 2011 | 04:40 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
After wire wheeling my shafts to metal, I followed with Por-15. I then top coated with Seymour Cast Blast. I will have to see if I can take a picture to post later tonight.
Old Feb 7, 2011 | 08:09 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
All depends whether or not you are trying to return the car to the way it left the factory. I scrubbed mine with brass brushes, scotch brite pads and degreaser until I though my arms would fall off. The tubes were originally shot-peened and left natural from the factory, so I wanted to keep them that way. No sand or glass bead blasting, sandpaper or steel wool for me. After installing new u-joints, I wiped them down with Os-Pho and then sprayed them with CRC SP-400 corrosion inhibitor. Leaves a slightly sticky yellowish film but hey...better than rust. May have to wipe them with a solvent every so often and then re-spray with the CRC.
If you aren't into the original look and just want them to be pretty, then do whatever you want!
Old Feb 7, 2011 | 10:42 PM
wheatpj's Avatar
wheatpj
Thanks everyone for all the good information and photos. I think I’m going to try to see how well I can get the half-shafts to clean up. If I get good results I will spray them with a satin clear. If I can’t get a finish that will look good with the clear, I will clean them up enough to lay down a good finish with Eastwood Brake Gray.
Thanks again
Pat
Old Feb 8, 2011 | 08:06 AM
Sigforty's Avatar
Sigforty
Here is the picture I said I would get.
To Half-shaft refinish
