Holley Carb
Old Feb 6, 2011 | 08:51 PM
donnie1956's Avatar
donnie1956
Default Holley Carb
What model of holley carb is this. I have looked all over for a tag or number and can't find anything. Where is the model number or part number located?
https://picasaweb.google.com/donpets...58169096991298
Old Feb 6, 2011 | 09:04 PM
7t9l82's Avatar
7t9l82
on the front of the choke tower
Old Feb 6, 2011 | 09:12 PM
Snoopysvet's Avatar
Snoopysvet
Old Feb 6, 2011 | 09:30 PM
gingerbreadman1977's Avatar
gingerbreadman1977
that fuel inlet set up looks real sketch
Old Feb 6, 2011 | 09:56 PM
donnie1956's Avatar
donnie1956
Thanks,
Old Feb 7, 2011 | 01:22 AM
sly vette's Avatar
sly vette
Sure is alot of rubber going to that carb. And is that a Bolt sticking out of the front bowl???
Old Feb 7, 2011 | 02:54 AM
snoopykissedlucy's Avatar
snoopykissedlucy
Whoa....the sight plug is comprised of a bolt.
And the fuel lines are pretty much all rubber. Please be careful, it's a fire waiting to happen. Please use metal lines as much as possible.
What we do know based on the pic:
It is a vacuum secondary 4 barrel Holley.
It has the quick change vacuum secondary housing.
Based on the shape of the intake below the carb, it is NOT a spreadbore carb.
The choke mechanism is completely missing. The choke blade is just along for the ride.
As far as size: it can be anything from a 600-850.
Give us the LIST # on the carb air horn and we can help ya out.
Old Feb 7, 2011 | 06:58 AM
donnie1956's Avatar
donnie1956
Heres the other side. Notice the throttle cable and spring return. Bubba did some fine work here. Lots of clean.
https://picasaweb.google.com/donpets...58166051824354
Old Feb 7, 2011 | 02:07 PM
Billysvette's Avatar
Billysvette
Looks to be a vaccum secondary 650 or 750. Man Mr BUBBA got to that engine.its a miracle that it ran like that for long. Really ugly looking,it has to be fixed
Old Feb 7, 2011 | 08:47 PM
donnie1956's Avatar
donnie1956
Front of carb.
https://picasaweb.google.com/donpets...28843440519954
Old Feb 8, 2011 | 10:51 AM
Snoopysvet's Avatar
Snoopysvet
cant read the numbers, a bit too blurry, what are they?
Old Feb 8, 2011 | 05:57 PM
donnie1956's Avatar
donnie1956
I will take a another picture tomorrow.
Old Feb 9, 2011 | 07:28 PM
donnie1956's Avatar
donnie1956
http://www.facebook.com/photo.php?fb...4530298&ref=nf
Old Feb 9, 2011 | 08:16 PM
gerry72's Avatar
gerry72
I can't read the numbers and it's hard to say from the shallow view of the venturi, but it looks like a model 1850, 600 cfm. Based upon the other carb features, it could be only a model 1850 or a 3310, 750 cfm. You'll have to get the carb LIST number from the front of the carb's airhorn, then go to the Holley tech site and look up the carb. Someone also added a secondary metering block to the thing so don't let that throw you off thinking it's in the 4150 line. I'm not a member of Facebook so the link serves no purpose for me.
Old Feb 9, 2011 | 08:23 PM
donnie1956's Avatar
donnie1956
The numbers on the choke tower are 80570 with 0913 underneath.
Old Feb 9, 2011 | 08:36 PM
ShraderMan's Avatar
ShraderMan
The 80570 is the model. It appears to be a street avenger, but that model would be 0-80570. The last three digits denote the CFM rating (570 CFM in this case). Holley supplies the rubber fuel lines with the carb inthe box, but Jegs / Summit has a nice aftermarket fuel line setup. Even has a 1/8" NPT port for a pipe thread.
Old Feb 9, 2011 | 08:40 PM
ShraderMan's Avatar
ShraderMan
If you want the pretty steel lines, I believe this is a 4150 series Holley. They will run you about $35. Holley part 34-150.
To Holley Carb
Old Feb 9, 2011 | 08:42 PM
donnie1956's Avatar
donnie1956
Is worth fixing up or should I move on. No choke, missing linkage? Is it ok for 383?
Old Feb 9, 2011 | 08:47 PM
Scott Marzahl's Avatar
Scott Marzahl
If it is a 570 cfm carb its too small for a 383, look for a good 750 cfm carb, there are usually a few on craigslist.
Old Feb 9, 2011 | 10:06 PM
donnie1956's Avatar
donnie1956
Thats what I thought. I only drove it away from Bubbas about 15 miles and it stumbled all over itself when I put my foot in it.
