Theoretical question about "Quench"
Old Feb 11, 2011 | 01:49 PM
gkull's Avatar
gkull
Originally Posted by CA-Legal-Vette
Minor aside. Is there a way to predict piston rock? The idea of reducing the quench until the piston hits the head makes me uncomfortable.
If there is a prediction I don't know how to do it.
I've always during the assembly of the short block. Use a dial indicator on the on both the 12 o'clock and 6 o'clock. Place the piston at exactly TDC. Then use a hammer wood handle and press one side of the piston (piston rock)
Way to many variables. Like how tall is the piston, bore size, piston pin placement. Like motorhead's and my 427 4 inch stroker small blocks the piston pin is very close to the top behind the oil ring. Piston to wall clearance, and type of rings. How heavy is the piston.
So if you have over say .036 or .040 you are good to go. It's people trying to get down around .030 that have to start measuring everything.
Old Feb 11, 2011 | 02:00 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
That isn't half bad. Presumably the rock would be less on a warm engine than on a cold one so this would be a worst case measure.
Old Feb 11, 2011 | 03:50 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Originally Posted by 427Hotrod
One thing of note is that when GM built this stuff they used .020-.025 or so deck height and steel shim head gaskets that were only .018"-.021" or so. So that means total quench was only around .038" to .046". They weren't using .038"-.041" composition gaskets like most folks use during rebuilds.
Maybe The General DID know a little something??
JIM
Which side and which corner had the good squish distance, I am sure you have measured deck heights and done some straight edge testing on OEM GM engine blocks
I am happy to see others that aren't completely caught up in the "squish" factor and those who give honest answers based on there own experiences are the ones to listen to like Jim above, Manuel Azevedo and of course my small block buddy gkull and others.
There is much talent and experience in this thread from those who answered instead of quotes from hot rod books and other internet sources I was expecting to get
Old Feb 11, 2011 | 04:22 PM
69autoXr's Avatar
69autoXr
JIM
Is it ill-advised to run a steel shim head gasket on a motor rebuild without having the block decked?
Old Feb 11, 2011 | 05:27 PM
'75's Avatar
'75
I'm running the shim head gasket on mine with the vortec heads and no block machining. No problems.
Old Feb 11, 2011 | 07:06 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
I like to target .035 to .042. Whatever the deck clearance is, just subtract from that to select a gasket thickness.
Old Feb 11, 2011 | 07:27 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Originally Posted by Manuel Azevedo
Your right maybe GM does know something or maybe just cheap in parts used.
I'll bet cheap had a LOT to do with it! But for fast machining and throwing them together, they really didn't end up with stuff that terrible. They ran well for what they were over the years.
And yep....you can sure get a lot of variance on a stock block on decks! As mentioned...fast machining for sure!
But the fellow who rebuilds one with cheapo replacement pistons that put it .040"+ down in the hole and uses some .050" gaskets has a real pig!
JIM
