Default no lighting behind dash...help?
Old Feb 12, 2011 | 10:53 AM
scyzoryk23's Avatar
scyzoryk23
Default Default no lighting behind dash...help?
I am not getting any illumination of my speedo/tach. The center console lights work fine.
All gauges are functioning, and circuit boards look fine....any ideas?
S.
ps. Car is 1981 Vette.
Old Feb 12, 2011 | 12:19 PM
sly vette's Avatar
sly vette
Bad ground.
Old Feb 12, 2011 | 03:42 PM
7T1vette's Avatar
7T1vette
There is a grounding wire running from the backside of the speedo/tach housings to the left/front door pillar. The wire could be broken or the connection could be corroded. The easiest way to test for this problem is to get a length of wire, connect one end to a known good grounding point, and touch the other end to the speedo/tach housing (with the ignition in the ON position). If you have a bad ground on that system, the lights should work when you hook up the 'dummy' ground wire.
Old Feb 12, 2011 | 10:14 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
7t1 is right.. just go to the connector on the back of the cluster. From the picture below, where the number 4 wire is located, run a jumper to it.
You should also check to make sure you have power on the number 10 wire. No power, then you have an issue somewhere else.
18243
To Default no lighting behind dash...help?
