Fuel line and thread lock
Old Feb 12, 2011 | 01:25 PM
Cobfree's Avatar
Cobfree
Default Fuel line and thread lock
would anyone recomend using treadlocker or seal tape on the brass theads? New lines and fittings are leaking
Old Feb 12, 2011 | 02:14 PM
dembo's Avatar
dembo
My powerjection installation manual highly recommends to use blue loctite threadlock on all fuel line connections, which I'm doing. System is not ready for startup so can't tell if any of them don't leak.
Nick
Old Feb 12, 2011 | 02:19 PM
Cobfree's Avatar
Cobfree
I just took it all apart and started from the bottom up. NO LEAKS, I must have had it in a bind. Thanks I will take off and use blue loctite
noonie's Avatar
noonie
It is always good to lubricate the threads and inside of a tube nut when torquing, the same as you do bolts and nuts. Any galling and minor interference including the flare area can cause leaks. This helps mate all surfaces.
I usually use copper antisieze on the tube and nut threads, being carefull not to get it in the tube or fitting. Helps years later on disassembly.
On brass pipe threads a sealer is helpfull, but on the small automotive sizes, you can usually get away without it.
Again, lubricating will help, but I use Permatex Aviation Form-A-Gasket No. 3 Sealant, resistant to gasoline, and also acts a lube. This won't plug anything downstream as a tape can, if improperly used.
Also FYI, contrary to a lot of opinion, teflon tape (white or yellow) is not harmed by gasoline to cause failure, but upon multiple assembly cycles, it becomes shredded on the female threads and can be carried downstream.
Old Feb 12, 2011 | 02:23 PM
Cobfree's Avatar
Cobfree
got it thanks. I did use whtite tape on the bottom connection and it did help.
Crazy.. back to the garage. this forum is the best I have ever experienced
Old Feb 12, 2011 | 02:48 PM
Cobfree's Avatar
Cobfree
Well I blew it. I tighten the inlet on the carb and stripped it. Now I'm lost
Old Feb 12, 2011 | 02:56 PM
U17's Avatar
U17
"Parker Fuel Lube" or Permatex #2 ....Whatever you use keep it away from at least two threads going into the other piece.
Old Feb 12, 2011 | 02:59 PM
Cobfree's Avatar
Cobfree
I will get some.. Worth a try
Old Feb 12, 2011 | 04:07 PM
G-Sting's Avatar
G-Sting
Hopefully, it is just the fuel line nut threads you stripped. Check it carefully. If so, you just have to replace the hard fuel line.
I have used the yellow (gas) teflon tape on fuel line connections. You just have to be careful when disconnecting, to clean it all off and put on new when reconnecting. Seems to seal well and you don't have to over-tighten. Be sure to use good flare nut wrenches. They can be a little pricey, but will save you headaches and money in the long run.
Old Feb 12, 2011 | 05:53 PM
Cobfree's Avatar
Cobfree
Not so lucky, for some reason I can not post a picture so I will start a new one.
To Fuel line and thread lock
