Parking Brake Light
Old Feb 12, 2011 | 07:12 PM
Berniep92's Avatar
Berniep92
5th Gear
Default Parking Brake Light
I have a 1975 stingray and My parking brake light will not go off. I have checked the cables and they all are working correctly. I have also replaced the Parking Brake sensor switch in the center console. the light still will not go off. Any suggestions?
Old Feb 12, 2011 | 07:35 PM
BHRIG's Avatar
BHRIG
Have you had any brake work done....?
If so , your brake proportioning valve might have to be reset.
If not could be switch in console at base of brake handle has to be adjusted.
Old Feb 12, 2011 | 07:39 PM
Duke94's Avatar
Duke94
Pull the connector off of the proportioning valve switch. It's mounted to the frame under the M/C. If the light go out, then you may need to bleed the brakes.
Gary
Old Feb 12, 2011 | 09:04 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Bleed the rear first !!!
Old Feb 12, 2011 | 09:29 PM
my 76 ray's Avatar
my 76 ray
Gary
That's going to be the easiest way to determine if the problem is in the parking brake or the hydraulic brake system.
Old Feb 13, 2011 | 11:32 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Berniep92
...the light still will not go off. Any suggestions?
Adjust the light switch on the parking brake. If it does not close with the parking brake off, the dash light will stay on.
Old Feb 21, 2011 | 11:22 AM
Berniep92's Avatar
Berniep92
5th Gear
Finally had a chance to follow your advice. It worked. Thank you my light is now off.
Old Feb 22, 2011 | 01:29 PM
reddog76's Avatar
reddog76
Which one worked for you? Sensor adjustment or proportion valve?
Reddog76
Old Feb 22, 2011 | 03:58 PM
Berniep92's Avatar
Berniep92
5th Gear
It was the proportion valve. I had parked the car on a steep hill (nose facing down hill) when the light was triggered and I guess the valve closed. I reset the valve by pressing hard on the brake, and the light went off.
Old Feb 23, 2011 | 12:50 AM
kdf1986's Avatar
kdf1986
Good job. I wish all brake issues were this easy to fix.
kdf
To Parking Brake Light
