Reverse Light Question....help?
Old Feb 12, 2011 | 11:16 PM
bluegtp's Avatar
bluegtp
Default Reverse Light Question....help?
Here's my problem:
My reverse light switch by the gear shifter works just fine. I'm getting power to & from there like it should. I'm reading 12V leaving the switch on the LT GRN wire (when in reverse and ign on). I'm not reading 12V at the rear tail light harness connection where bundle of wires comes out of the fuse box. I pulled the fuse and put a jumper in place and still nothing at the LT GRN wire at rtl harness.
Does this LT GRN wire travel anywhere else inbetween (besides the fusebox)the rev. light switch and the rear tail light harness connection? Fuse box layout says the turn signals are on that same fuse, could this have anything to do with it? (I'm not sure how it could though)
I bypassed the fuse box and everything works just fine. (went straight from lt grn wire at switch to the lt grn wire on fuse box side of rtl harness) I'd rather fix this issue instead of "rigging" it up like this!
Any help is greatly appreciated!!!!
Ryan
Old Feb 13, 2011 | 12:34 AM
...Roger...'s Avatar
...Roger...
The lt green should leave the switch (c109 conn) goes through dash to the rear harness c124 conn and then to the rear of car.
The green doesn't go through the fuse box.
Old Feb 13, 2011 | 01:15 AM
...Roger...
Wondering now if there is a jumper in the circuit for a 4 speed car ? If so that might be your disconnect.
Old Feb 13, 2011 | 02:57 AM
bluegtp's Avatar
bluegtp
Thanks again for the quick response! You've helped a lot in the past week or so.
I do have an auto th 350 transmission.
I followed the lt grn wire from the switch until it went into the large loom and that lead back to the fuse box. Followed from the rear tail light harness connection into large loom that lead back to the fuse box. I would assume the lt grn wire just passes through the box then without it being fused.
There has to be another connection point in that circuit.....well that or the previous owner cut the wire somewhere inbetween.
I tried searching but didn't come up with much info on this issue.maybe someone else can chime in if there perhaps is some kinda jumper in that circuit????
Old Feb 13, 2011 | 08:02 AM
...Roger...
Here is a link to a diagram from a 78 and its the same as your 79 except the 139 conn is referred to as 175 on the 79.
Unless there are 2 wiring harnesses , 1 for 4sp and 1 for auto I'm guessing there is another connector so a 4sp jumper harness can get into the circuit.
The 4sp wiring connector pink and green is usually just below where the throttle cable comes through the firewall on the engine side,check there and see if you can spot something.
http://www.corvetteforum.net/c3/tune.../index11.shtml
Old Feb 13, 2011 | 09:02 AM
7T1vette's Avatar
7T1vette
Disconnect that wire at the shifter, then use an ohmeter to check continuity of that wire from the connection at the rear of the car to the connection at the shifter. You will then know if it is an 'open' circuit or not. If it is, you can then use a needle to puncture the insulation of that wire at some spots along that path until you find the [physical] area of the break in the wire. That should help you find the problem and resolve it.
Are you certain that the problem is with that wire and not with the ground connection at the rear of the car?
Old Feb 13, 2011 | 10:52 AM
bluegtp's Avatar
bluegtp
Roger:
Ill have to check for that 4 speed connection later today like you mentioned.
7T1vette:
Yes ground is certainly not a problem....my taillights/running work just fine....the problem is somewhere between the switch and where the connection at the rear tail light harness.
Old Feb 13, 2011 | 05:15 PM
...Roger...
Ryan
Ryan just to confirm. You are reading this at the 8-10 wire connector that is just above the drivers side kickpad , the conn that goes to the rear with all the rear lighting and such in it ?
I just wanted to confirm we were all on the same page and that you weren't talking about the harness at the "rear" of the car.
Hopefully someone with their dash and console out can chime in as to if there is a connector that could have come apart or you actually have a broken wire.
Old Feb 13, 2011 | 08:16 PM
bluegtp's Avatar
bluegtp
Yes we are talking about the same connection. I'm testing at that connector where it goes to the rear of the car. (I'm not testing at the rear of the car, I don't even have the rear harness connected right now)
take a look at this picture. Looks like someone has previously ripped the green wires out or spliced into them at one time. Judging by the insulation it looks like it was somehow ripped out. I haven't made a connection yet because I can't find the other end of the lt grn wire. Trying to decide if it's worth my time to make a solder connection right there or just splice into the ltgrn wire at the switch and run a new wire up to the wiring harness leading to the rear of the car. Either way you are right, there is a connection down there for a manuel trans. and that is where the issue was. I guess I can't take much for granted with this car!
To Reverse Light Question....help?
