Siphon as much as you can and refill with about 5gal. of new. Change oil and filter. Then try it. This is just to get it running. See what else needs attention after a slow ck. out drive around the neighborhood. Then do brakes, belts, hoses or whatever else. mike...
I'd change the coolent also. If the brake fluid looks low in the master cylinder get under the car and look for leaking calipers before attempting to drive the car.
The e-brakes can sieze up from sitting also, so make sure the car rolls freely.
To be honest 2.5 years is not a terribly long time for any major problems assuming that everything was in pretty decent shape before the storage. I am not so sure that I would siphon the gas after that period of time but it certainly couldn't hurt if you are so inclined. You might try some dry gas and run the gas out of the car-it will probably run fine. The oil and filter are a definite simply because conventional oils really should not be in the crankcase for more than a year. Changing the brake fluid and checking for leaks is prudent but again you are probably going to be fine on that front too if the brake fluid was changed in the recent past before the storage. As for belts and hoses, I have gone 10 years on those items with no issues, driving in the summer months only. I have also gone 4-5 years on the coolant with zero issues with cooling or radiator deterioration (25 years old and looked just about perfect internally when I changed it recently to a Dewitts).
Basically, I think that you will be rather surprised at how well everything holds up for a couple of years-more if stored in doors. Just my experience with my C3 after 27 years.
My '78 sat for longer than that and fired right up on what gas was left in the tank and what I poured in from the lawn mower gas can.
I think I'll try JB78's idea, but I have one question.
My car was not stored in the best of situations. I wasn't exactly out in the open, but it was not in a controlled environment either.
I was truly exposed to the Kansas winter for 2 seasons. Cold had hell!
this cheap gas we have now days might have caused a little varnish in the carb.might have to pull the carb and give it a cleaning so the jets and accelerator pump are not gummed up.
i have had this happen just sitting over the winter with out the stabil in the fuel
I've had cars sit for longer then yours and you get gas up to the carb and fire and it will bust right off. Don't spin it over to long with dry cylinders. I always spray some lub into the spark plug holes first.
