Carburetor replacement
Old Feb 13, 2011 | 07:09 PM
Cobfree's Avatar
Cobfree
Default Carburetor replacement
I stripped out the inlet to the fuel and need to have it repaired. What is the thought about replacing OE carbs? Should I stay with OE or upgrade. If I upgrade what should I consider. It is a Carter quad on a 68 matching number car with a 327, 300HP.
Old Feb 14, 2011 | 12:30 AM
7T1vette's Avatar
7T1vette
Many auto part stores have, or can order, a repair kit for that stripped thread. It's sort of like a heli-coil kit, I believe. And that would be preferable to switching out carbs, IMO.
Old Feb 14, 2011 | 08:39 AM
Cobfree's Avatar
Cobfree
Thanks for the info and money saver
Old Feb 14, 2011 | 05:45 PM
Cobfree's Avatar
Cobfree
Found a local carb shop that will rebuild the carb and install heli-coil. thanks
To Carburetor replacement
