Fuel Line Question
Old Feb 14, 2011 | 10:02 PM
Tim81's Avatar
Tim81
Default Fuel Line Question
Hello,
Is anyone using regular rubber fuel lines for the transition from the metal lines from the tank to the fuel pump? Or should the preformed hoses always be used?
Thanks Tim
Old Feb 14, 2011 | 10:32 PM
steve228's Avatar
steve228
Just my .02 cents...I used all steel lines.The onlu place I used rubber lines is the transition
from the rear line to tank.But then I took lars advise.He has a good write up on forming your own.
Old Feb 14, 2011 | 10:34 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Don't let your hose get kinked.
On my '74 only one is preformed - has S shape. But u can make hard line extensions onto the fuel pump (then add straight flex hose to make the connection to hard lines to tank) if needed and craft your own routing. My carter fuel pump had different inlet/outlet fitting locations than stock. Just stay away from heat (exhaust pipes) and don't let the hose kink.
cardo0
sly vette's Avatar
sly vette
I use rubber from the tank to the hard line and from the hard line to the pump. No problems. Just don't make it too long, so it won't kink.
Old Feb 14, 2011 | 11:24 PM
7T1vette's Avatar
7T1vette
The problem with that particular hose is that it has two sharp bends. With 'regular' fuel line, it will kink-up and close off the fuel flow. That's why you can get that one "pre-formed" and, thus, it costs more than stock hose.
If you can find some good quality hose that will not close-off when making those tight bends, go for it. If not, buy the ready-made one.
Using synthetic rubber fuel line in transition before the fuel pump is fine. Installing it down-stream of the fuel pump is what is risky. Before the pump is merely "gravity feed"...no real pressure on the fuel. After the pump, the fuel is pressurized, and if the hose breaks it sprays fuel all over the headers and a hot engine compartment. Not a good idea....
Old Feb 15, 2011 | 03:29 AM
vettehardt's Avatar
vettehardt
I've use rubber lines on my 73 for years with no major issues because of them. I did however replace all of them a couple of years ago because i saw one was starting to dry rot. I did have a small fire under the car right before this, but that was actually from the metal line on the frame which developed a hole. Sprayed right onto the hooker headers. I was coming in from an autocross run and somebody said they saw fire. I shut off the motor, grabbed the extinguisher and opened the hood, but the fire was already out.
I hvae rubber from the tank to steel line on frame, from frame line to pump, and from pump to carb with an inline filter. I didn't use a preformed line from the frame to the pump. I do have a Holley pump and you can move the inlet and out let to a more suitable position. I also have a section of hose in place of where the steel line had the hole. If i ever do a body off, i will replace that line. They have lines rated for fuel injection if you are worried about pressure, but our manual pumps really don't produce that much pressure.
Old Feb 15, 2011 | 07:40 AM
Tim81's Avatar
Tim81
Good Info from everyone. I really appreciate it....Tim
Old Feb 15, 2011 | 06:29 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
I used a high quality rubber hose from the frame to the pump inlet. I don't see any kinks, but then again...I am experiencing what I believe to be fuel starvation under hard acceleration. Thinking seriously about using a pre-formed "S" shaped hose there.
To Fuel Line Question
