Plastic insulators in rear spring
Old Feb 17, 2011 | 03:35 AM
Simmo's Avatar
Simmo
Default Plastic insulators in rear spring
What is the purpose of the plastic insulators in rear transverse spring. Can I remove them.
Old Feb 17, 2011 | 03:44 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I think they eliminate the metal-to-metal friction noise, but again, I may be wrong.
Old Feb 17, 2011 | 06:13 AM
Aussie79's Avatar
Aussie79
More importantly, they eliminate or at least reduce the metal to metal friction, which is noisy yes but also important to allow the leaves of the spring to each react properly to bending moments, in other words, without them the spring has more tension and isnt doing its job properly. They are not expensive and easily replaced so replace them.
Hope this helps, Dennis.
Old Feb 17, 2011 | 08:30 AM
Alan 71's Avatar
Alan 71
Hi,
I believe the liners allow the spring leafs to move independently of each other which gives the spring it progressive 'rate'.
I, too, think they need to be there.
Regards,
Alan
To Plastic insulators in rear spring
