1975 L 48 Corvette Speed?
Old Feb 17, 2011 | 08:23 PM
David Hutton's Avatar
David Hutton
1st Gear
Default 1975 L 48 Corvette Speed?
I have a 75 L48, I know that the 75 sucked on Hp with only 165 Hp My Question is my top speed is about 100 mph is that normal and what can I do to speed it up alittle
Old Feb 17, 2011 | 09:35 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
NO!.... I had a low hp in mine and seen 130 from time to time...
Old Feb 17, 2011 | 11:29 PM
7T1vette's Avatar
7T1vette
It all depends on what axle gear ratio you have. A 'standard issue' '75 would likely have gone 110+ mph as shipped. With some tuning, it could probably get near 120. Either you have a gear ratio that won't allow you to reach higher speeds, your engine is 'sick' (or in poor tune), or you are not getting full opening of the carb secondaries.
Old Feb 18, 2011 | 07:42 AM
LancePearson's Avatar
LancePearson
I don't know what exhaust the '75 had but my '76 had a 2-1-2 exhaust going through a huge old pellet cat. converter. When I put straight duals on, each with a ceramic grid bullet high flow cat converter and flowmasters the engine gained 750 rpm and 5-10mph more at the top end of each gear though I haven't tried fourth top yet. Part of it was the better breathing with more than double the exhaust outflow compared to factory and part of it was the elimination of the old crapped up pellet cat converter. Power now is "uniform" through each gear from start to finish and it wasn't before. I suspect you either have a rear end that isn't something like a 3:36 or your cat converter if it has one is crapped up. If so, modernize the cat converter to a modern high flow one if you want to keep stock systems and I bet you see performance improvement too. I sure did.
Old Feb 18, 2011 | 10:21 AM
Robert Anderson's Avatar
Robert Anderson
When I had my 75 (automatic) I got about 115 and then it just ran out of breath.
To 1975 L 48 Corvette Speed?
