another lighting mod i've had some curiosity about is setting up to have all four headlamps run as driving lights (hi-low beams). i think that would make for a unique look...
But the headlamp doors would be up.
If the car is pre-1980 you can use Hella OptiLux (or similar) driving lamps behind the grilles. They are very bright. This will not work on 1980-82 as the grille slats are slanted (not completely horizontal).
Looks sweet, I thought about that too, I was going to cut in some driving lights but didn't want to cut up the grilles, very nice job!
