Valve lash?
Old Feb 21, 2011 | 05:27 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Default Valve lash?
I will be attemting to adjust my valve lash on my 77 wednesday. I have "Lars" write up on it. Will I be able to turn the motor with a nice wrench on the harm. balancer nut? (battery/coil disconneted of course) Or will I need to take the plugs out so there will not be any compression? Thanks...
Old Feb 21, 2011 | 05:58 PM
trainor's Avatar
trainor
I just did mine the other day. With plugs out it will turn over much easier. I did mine with them in. Just make sure to turn the motor over the correct way as not to loosen Bolt on the balancer.
Old Feb 21, 2011 | 07:12 PM
Roco71's Avatar
Roco71
I was able to turn my motor over with a wrench on the alternator pulley nut with plugs in without any problems.
Old Feb 21, 2011 | 08:21 PM
'75's Avatar
'75
This is the easiest, even works on large diesel engines.
Old Feb 21, 2011 | 08:36 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Thank you guys!!
Old Feb 21, 2011 | 09:35 PM
l88rocket's Avatar
l88rocket
Hyd lifters? just start it and adjust them with the motor running, back them off till they clatter and then tighten them till there quiet then another turn and 1/2 on them
Old Feb 22, 2011 | 06:00 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Turn and 1/2 ? or just 1/2 ?
Old Feb 22, 2011 | 07:24 PM
Roco71's Avatar
Roco71
Just 1/2
Old Feb 22, 2011 | 08:46 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default A little more to it than listining for clatter.
What u want is to get to zero lash then adjust 1/4 to 3/4 turn tight. Zero lash is where the p-rod can still turn sideways but doesn't move up or down anymore - yes u can do this with your fingers. Best method i know is to cut open the top of an old vlv cover and swap it on the head - this will reduce oil splash the most. Once the engine is warm and idling loosen the rocker until u can move the p-rod up and down (may clatter now). Next tighten until p-rod won't move up or down but u can still roll it side to side with your fingers - this is zero lash. Now tighten 1/4 to 3/4 turn tight and move on to the next rocker.
This is much more accurate than when the engine is stopped and the lifters may not even be pumped up with oil.
Good luck in Palm Beach,
cardo0
Old Feb 22, 2011 | 09:53 PM
noonie's Avatar
noonie
Originally Posted by cardo0
...when the engine is stopped and the lifters may not even be pumped up with oil.
cardo0
Did you leave the springs out?
To Valve lash?
