alt bracket help
Old Feb 23, 2011 | 01:48 PM
7dSHARK's Avatar
7dSHARK
Default alt bracket help
good morning...70 vette with same era engine from a camaro, don't hate. it's a small block with headers. the heads have no bolt holes in the end so i am using a two piece alt bracket purchased at a local kragen. it shares a bolt with the header and i hate the design. no a/c no power anything. i just need a bracket that works better. any help would be greatly appreciated. pictures would be great...thanks
Old Feb 24, 2011 | 01:55 AM
texas jim's Avatar
texas jim
The older heads didn't have all the bolt holes the newer ones have, f/ A/C, smog pump, etc. You'll need to go to a junk yard and get an alternator bracket from one of the older Chevy small blocks. If I'm not mistaken, I think the alternator bracket on the older ones attaches to the water pump (top)(same bolts), both the stationary one ( a triangle shape) and the adjuster (a flat plate on top and bent over in the front part w/ the long slot).
A Camaro engine, still a sbc, nothing wrong w/ that. The old ones were good ones.
Old Feb 24, 2011 | 12:40 PM
toddalin's Avatar
toddalin
Header-mount brackets are scarce in that they are all the same design. It is weak and it sucks but there are a few ways to improve it.
A double J-bar with 1/2" long solid spacers is a start and really firms things up.
Take header bracket to a welding shop and have them do this:
And you can add another brace to the alternator:
Old Feb 24, 2011 | 09:52 PM
snoopykissedlucy's Avatar
snoopykissedlucy
Very nice Toddalin! I've never seen the double J set-up like this.....great idea!
I'm trying to figure out the extra heim joint extension coming from the center header tubes. Can you post a closer pic of this?
Old Feb 24, 2011 | 11:22 PM
Kid Vette's Avatar
Kid Vette
This is the bracket that you need.
It works with the stock bracket in front.
Old Feb 25, 2011 | 12:29 PM
toddalin's Avatar
toddalin
I made the "L" on the alternator using an iron fence hinge, my cutoff wheel and grinder. The 1.9" spacer on the header is from March (they didn't even charge me). I don't recall who made the heim joints/threaded spacer, but these are common and if you decide to do this, I can measure the length for you (~6").
Old Feb 25, 2011 | 06:50 PM
corvetteload's Avatar
corvetteload
http://www.alangrovecomponents.com/i...Large/209L.jpg
OR
http://www.alangrovecomponents.com/i...Large/211L.jpg
PLEASE IGNORE---PROBABLY WON'T WORK ON A VETTE DUE TO FRAME
Old Mar 3, 2011 | 07:13 PM
7dSHARK's Avatar
7dSHARK
thanks to everyone for your time, wisdom and the pics...matt
Old Mar 3, 2011 | 08:12 PM
sokoloka's Avatar
sokoloka
http://www.summitracing.com/parts/SME-2001/
Just pitched my header mount bracket and installed this one instead about 3 days ago.
Old Mar 3, 2011 | 08:39 PM
kdf1986's Avatar
kdf1986
Sokoloka, that is a good setup.
For the person asking though I dont think he has holes in the Camaro head to do this type of install.
I do like photo you posted and will try out the link for one of my applications.
kdf
Old Mar 31, 2011 | 03:17 PM
brian schuetta's Avatar
brian schuetta
Sokoloka - What WP do you have, long or short? And another question, is there really a difference between a standard short WP and a stock Vette one? I have to start from scratch for WP, pulleys, brackets,etc. Any advice. For SBC IN 74'
To alt bracket help
