well, took a break for the day
UPDATE:--everything except t-arms out of the back of car (they're rusty but are cleaning up pretty well). finally got the top bolts CUT out of the shocks, did a (what you guys call a Bubba) fix on the rear frame crossmember after i broke the bolt off, pulled radiator and discovered that the support does NOT have to be replaced (damn shop must think i'm just a stupid broad), motor is being pulled this upcoming week thanks to a neighbor with a picker. and started contacting the members on the forum with the crossmembers for sale. if i order the parts next week, i hope to be on the road by june 1st. like i said-"HOPE"
thanks everybody for all you help :cheers:
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: well, took a break for the day (erika1977)
Erika, you are a hell of a woman! If I lived a 1000 miles closer to you, I come and help you! Good luck with all your work!
If you're looking for another crossmember,I have a spare rear differential mount crossmember. The rubber is good.there is a small nick in one bushing but I would use it.There is a little bit of rust scaling where the top plate is welded on the bottom. I was going to POR 15 it and store it. If you're interested, I paid $50 for it, maybe I can get some pictures to you on Tuesday. It came out of a 69 should fit your car but you may want to have someone double check it.
Gary
[Modified by gtr1999, 10:07 AM 4/13/2002]
Gary
Re: well, took a break for the day (LeAnn82Collector)
thanks everyone!! i'm having fun!! (i think!) :crazy:
now if i can only figure out where the rear bolts for the seats are :confused:
Awesome...good job. Beware of shops that have better salesmen than mechanics...look things over yourself. Wow...a girl that likes to get greasy. I think I'm in love.
