Rear window
Old Apr 14, 2002 | 10:16 PM
Bobbyg75's Avatar
Bobbyg75
Default Rear window
Going to remove the rear window prior to painting my 75. Does not appear to be any type of fasteners holding it in. How is it removed?
Old Apr 14, 2002 | 10:23 PM
SizzleChest's Avatar
SizzleChest
Default Re: Rear window (Bobbyg75)
a sledge hammer and a steady hand. :lol: i think it's pretty tough to do and requires special tools.
[Modified by SizzleChest, 6:24 PM 4/14/2002]
paso's Avatar
paso
There is a soft sealant around the glass that holds it. If you undo the inside molding have someone push on the glass from the outside while your inside to hold it from falling. :)
Old Apr 14, 2002 | 10:27 PM
trw's Avatar
trw
I had to use a razor knife to cut the seal. Then carefully pushed.
Hope this helps.
Terry
To Rear window
