Car wont run over
Old Feb 25, 2011 | 09:55 AM
rgpta's Avatar
rgpta
Default Car wont run over
Just changed out engine. First had to solve electrical problem. Now all electrical is wokring howwever when I turn the key nothing happens. everthing is new, hei distributor, engine, tranny, starter, alternator,
I have electrical power to the car when I turn the key electrical fan comes on, interior lights, dash etc, just wont turn over
Any help ides appreciated.
Old Feb 25, 2011 | 10:43 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
lets eliminate stuff.....jump the solenoid and see if the car will crank....if it does then you know the starter/solenoid works.
if not.....there is your problem
if it does crank then measure voltage at the power wires coming into the solenoid....if you have no voltage there then that is where your problem is....there are fusible links in the wiring harness that goes to the starter/solenoid i bet that is where your problem is.
Old Feb 25, 2011 | 01:12 PM
hugie82's Avatar
hugie82
Also make sure you didn't leave any wire off the hot post on the alternator or possibly you installed the solenoid wire on the wrong post.
It happens to the best of us!!!
Old Feb 25, 2011 | 01:15 PM
rgpta's Avatar
rgpta
Default solved
i had the wire installed on the wrond selinoid post
thanks to all who replied
To Car wont run over
