Speedometer wrong
Old Feb 26, 2011 | 04:55 PM
cshelldiver's Avatar
cshelldiver
Cruising
Default Speedometer wrong
I was given a 1977 Corvette from my mom (original owner) this past Christmas. There are several small things (I hope) wrong with it. She let it set for about 10 years. One of the things wrong is the speedometer. I get it up to 80 miles per hour and my GPS says I am doing 70. There is less difference in slower speeds. Anybody have any ideas on what needs to be checked to fix this--I am very paranoid driving it because of this speedometer problem.
Old Feb 26, 2011 | 05:23 PM
Chromie69's Avatar
Chromie69
Welcome to the corvette club ..it must be a good car..make sure you go over the car real good..the speedo issue should be an easy one..if you are sure its wrong..I know my gps can give me weird speeds depending on how many satellites I am hooked to..anyhow the first thing to check is if you have the stock tire hieght..or size..if that is ok then I would try a speedo shop but you probably don't have one around you so..there is a formula to use when changing the gear in the trans..I don't have it on me but I will look for it..it may be just a tight cable though..BRB!
Old Feb 26, 2011 | 05:28 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
what size tires are you running? i bet they are not the stock size causing the issue
Old Feb 26, 2011 | 05:41 PM
laktrash's Avatar
laktrash
My speedo is wothless . when I changed to a 370 gear from the stock high gear (?). I think 55 shows maybe 80 I just go by tach , but you sure can impress your friends with 0 to 100 speeds , I really need to correct it. just kiddin'. just haven't got around to it.
Old Feb 26, 2011 | 07:34 PM
7T1vette's Avatar
7T1vette
You need to change the speedo gear in the tranny to one with 13% more teeth on it. Remove that speedo drive gear from the tranny and count the number of teeth on it, then multiply by 1.13 and order a replacement gear with that number of teeth (round off to the nearest whole number). I think it should be about 3 more teeth than what you now have. Good luck.
Old Feb 26, 2011 | 08:26 PM
cshelldiver
Cruising
Tires I have on it are 235/70 R 15------
Old Feb 26, 2011 | 08:35 PM
cshelldiver
Cruising
Old Feb 26, 2011 | 08:39 PM
cshelldiver
Cruising
Thank you for the welcome. I am very new to this--still learning how to do the forum too.
I am sure about the speedometer being wrong. The first time I drove it, after it was given to me--I was going to be really good and not speed. The speed limit was 60, so that is what I was doing and being passed by everything from a garbage truck, cement truck, minivan, and 18 wheelers----that is what made me suspicious!!! I was only doing 50 mph on the bypass!!
Old Feb 26, 2011 | 08:41 PM
cshelldiver
Cruising
After reading this a couple of times, I finally figured out what at speedo is!!! Short for speedometer--duh!!! That's okay, I will learn!!!!
Old Feb 26, 2011 | 08:42 PM
cshelldiver
Cruising
Okay, speedometer gear in the transmission!!! See? I am learning!! Will try to print out what you wrote and have someone check this for me.
Old Feb 26, 2011 | 09:15 PM
joewill's Avatar
joewill
yes, do this.. lots cheaper than dropping a size or 2 on your tires.. that will cost you 500$, that gear described above is like 8 bucks...
Old Feb 27, 2011 | 10:30 AM
bobs77vet's Avatar
bobs77vet
just for due diligence its probably worth comparing the circumference of the stock tires to the ones you have to see how much of a difference you have.
Old Feb 27, 2011 | 10:41 AM
BKbroiler's Avatar
BKbroiler
Speaking of tires, if the tires on there now are the ones the car was sitting for 10 years on, you should replace them before you try doing 80 mph again. They may look good, but they can fail at any time.
Old Feb 28, 2011 | 08:49 AM
71scgc's Avatar
71scgc
Agree with the bkbroiler post. Read the PSA sticky at the top of this forum...kinda spooky, I remember driving 100+ in my '74 911s with dry rotted and cracking yokohamas... not wise.
To Speedometer wrong
